1978 280z Turbo?
Old Aug 23, 2002 | 09:03 AM
Re: 1978 280z Turbo?
Of course it is possible! Looks at the rides section of this web page. I'm sure you have already seen the conversion done.
Best way is to use the entire engine and turbo setup. Don't try to put on a turbo onto your old L28 n/a block.
Are you planning on paying a shop to do the conversion? Or are you doing it yourself? It could cost you 4-5 thousand for a shop to do all the work.
You can buy a sweet 280ZX turbo for less than that. But really, most parts of the US you can find a turbo parts car for $1000 or maybe less. There is hardly nothing to fabricate to get it all to fit in. So it won't cost you all that much more. Of course, that also depends on how pretty you want the engine.
Old Aug 29, 2002 | 02:10 AM
Fredrik's Avatar
It´s not so hard to turbocharge a n/a engine. All you need is a turbo, a turbo fueller and a little time.
Old Aug 30, 2002 | 12:34 AM
Fredrik's Avatar
If you will be satisfied whith 220-250 hp you actually dont need to open the engine at all. The first L28 is possible to turbocharge because of the low compression (8.3:1). If you want to be sure you could replace the pistons and go for the p90 head. But if you want to keep it cheap and simple, just go for it!
This is of course not how the pros do it, but if you make sure the engine gets all the gas it needs(this is the important part) the pistons wont brake and you will have lots of fun for a small amount of $
<P ID="edit"><FONT class="small"><EM>Edited by Fredrik on 08/30/02 12:47 AM.</EM></FONT></P>
wallace millner
Jul 18, 2012 05:39 AM
DevilZ
May 15, 2010 06:39 AM
Texizgreat
Jan 2, 2008 06:41 AM
nismo619
Oct 8, 2007 11:07 PM
Jammer
Aug 3, 2003 05:14 PM
