1977 280Z Miss firing after engine is warm.
Old Jun 26, 2015 | 04:47 PM
polonick's Avatar
Good evening everyone,
I have acquired a 1977 280Z with L28E. I have worked out couple of electrical kinks to the point that the car will now start and idle.
The first 30 seconds of it running are flawless and then you can hear as if it stops firing on cylinders 1 and 2, when both plugs removed it makes no difference to idle. When I take it for a drive it sometimes runs smooth but will lose cylinders when under load.
Things I have done.
  • Fuel Pump
  • Fuel Filter
  • Converted fusible links to fuse box
  • new ignition wires
  • new distributor cap
  • new ignition coil
Things that help the idle and miss fire, timing advanced as far as it goes and AFM fingered to make the car run rich.
I need some more suggestions, because I am running out of ideas.
Thank you
Old Jun 26, 2015 | 06:03 PM
beg3yrs's Avatar
Have you tried cleaning your injectors?
Old Jun 26, 2015 | 06:17 PM
polonick's Avatar
I figure that one is ruled out since the car does run excellent on 6 cylinders while its cold for those 30 seconds, it does the same thing with the cold start valve unplugged.
Runs all nice and smooth with acceleration, then as if it hits a certain temp and it loses power and miss fires.
Old Jun 26, 2015 | 09:17 PM
beg3yrs's Avatar
Things expand when warm. If you've got a constricted line or orifice, the gunk could clog things up after it gets bigger. Running some fuel injector cleaner through probably wouldn't hurt.
Have you checked for spark on the missing cylinders? If it's there, you probably have a fuel problem.
BTW, I'm no expert on FI motors, just know some of the basics.
Old Jun 27, 2015 | 11:41 AM
polonick's Avatar
found the problem. Fuel feed line from tank was aerating the fuel.
any one know if its worth getting this tank torn apart or just get a generic racing fuel cell tank?
Old Jun 27, 2015 | 11:56 AM
beg3yrs's Avatar
Impressive. Kind of makes sense with your symptoms.
How did you figure that one out?
Old Jun 27, 2015 | 12:06 PM
polonick's Avatar
Well i noticed that when the fuel pump would shut off the tank would gurgle. I googled it and others are having problems with internal tank hose deteriorating and aerating the fuel.
Abeck85
Jun 7, 2014 07:54 AM
Meatwad
Apr 13, 2014 08:44 AM
Z_lover
Oct 17, 2012 10:27 AM
Sixer
May 10, 2010 08:19 AM
Tbone
May 13, 2004 11:17 PM
