1977 280 Project
Old May 19, 2011 | 02:46 PM
bmelton's Avatar
1977 280 Project
Just bought a 77 280. Been sitting for 15 years in barn. Couple of issues, when the engine is turned over the fuel pump does not start. Only after the key is turned back one click does the pump start. There is fuel then pumped to the engine. Another issue, not getting spark at the plugs. The resistor at the coil is hot to the touch, does anyone know what voltage should be at the positive side of the coil?
Old May 20, 2011 | 08:11 PM
theramz's Avatar
I have a present for you...
I'm pretty sure it's 8 volts. Since it's hot then you have some resistance but it is normal for the resistor to get hot because the excessive voltage is given off as heat. You should n't try to start a car that has been sitting that long without draining the gas.
Old May 24, 2011 | 05:47 PM
skittle's Avatar
Taste My Rainbow
12v to the coil, the FSM shows the correct way to test the coil.
Old Jun 10, 2011 | 02:24 PM
bmelton's Avatar
fuel pump issue resolved. Now no spark.
now to the no spark issue. I pulled plugs and checked for fire. Replaced coil, checked wires. Nothing seems out of place. Where and what should I check?
cole40
Feb 19, 2014 03:12 AM
WanganDevilZ
Jun 7, 2012 12:29 PM
FLORIDA ZEE
Sep 19, 2008 11:44 AM
dapper189
Jul 30, 2008 05:48 AM
AllmyZs
May 22, 2004 03:14 PM
