Pulling Oil Pan with out removing engine?
Old Jul 27, 2008 | 10:07 PM
at-jefft's Avatar
Uber n00b!
Hello,
Another newb question from me. I have a small leak in my oil pan gasket; Can I remove the pan and install a new gasket without pulling the engine? I have no equipment to remove the engine so I am not looking for a shortcut just a way to do it myself. Thanks, Jeff
EDIT: Forgot... L26 260z
Old Jul 27, 2008 | 10:14 PM
yes you can do it in any S30... its a tight squeez but easily done with the proper angling of the pan when pulling it. its a bitch to get the bolts though that are right over the engine cradle/steering rack
Old Jul 27, 2008 | 10:30 PM
at-jefft's Avatar
Uber n00b!
Great Thanks that just made my day! I hate giving the mechanics money.
Old Jul 28, 2008 | 01:21 AM
at-jefft's Avatar
Uber n00b!
Any preferences on gasket sealer? My first time replacing oil pan gasket any tips or things I should be aware of?
I am sure you could do a little trick with kind of lifting the engine enough. First unbolt your motor mounts. Then take a floor jack, and jack it between the engine and transmission. And then do it just enough to get to the oil pan a little easier. I did this trick replacing the rack and pinion in my '82 slicktop. Should be easier changing a pan gasket. Good luck man..
Old Jul 28, 2008 | 01:23 AM
RTV black should work fine. But also RTV red and blue...should work also. I think I used RTV black on my pan gasket. Before putting the engine in my '82 Top. Unfortunately though...I made the costly mistake. Of not changing out my front seal. So since then I have been leaking oil. And now with my commute to work. I am going through a quart of oil a week...
Old Jul 28, 2008 | 09:27 AM
go order a real gasket its cheaper and more reliable than gasket maker. napa or autozone or carquest will carry it dont cheap out for RTV or some crap like that.
Old Jul 28, 2008 | 10:30 AM
duowing's Avatar
NisTuner
I agree with the gasket thing. I can't tell you how many times I've had problem with sealants, to end up having to clean it all up, throw a gasket on and have no issues.
Old Jul 28, 2008 | 10:44 AM
Oh..I put on a gasket with the sealer of course. I haven't had any issues using RTV. But to each his own...you do what you like.
Old Jul 28, 2008 | 10:49 AM
at-jefft's Avatar
Uber n00b!
Ya! I never had plans to just use sealer. I am wondering what sealer to use with my new gasket. Do the gaskets come with sealer?
Old Jul 28, 2008 | 11:25 AM
dont need it if its a new gasket.... i spose you can put a very very thin of some high temp sealer around both sides.... but honestly not needed at all. i never used that crap when i had a new gasket
Old Jul 28, 2008 | 12:50 PM
at-jefft's Avatar
Uber n00b!
great, thanks.
Old Jul 28, 2008 | 11:15 PM
Ratfink's Avatar
Hoov for Pres!
Use a new gasket and throw the RTV in the trash.
Only times you should use it, are on multiple flange points. Like on the fronts and rears of intake manifolds/head/engine block junction on small block V8's.
RTV if used in small amounts will do nothing but cause poor sealing many miles down the road, and using too much will clog the inside of your engine up, and the pick up screen on your oil pump.
Who wants that?
There are times you need RTV. But, if you can make it work without, my best advice is to leave it in the tube.
This comes from many engine builds, motorcycles, cars, trucks, heavy equipment etc.
Any technician or mechanic that has been building for a while would agree.
Good luck with the pan. Sounds like a fun and dirty job. Only other advise I have is to use a pair of safety glasses. haha
Turbo Biscuit
Mar 29, 2012 07:37 AM
Stronginchrist
Nov 22, 2011 01:55 PM
ZBRICK
350Z Brakes, Wheels, Suspension and Chassis
Oct 15, 2008 07:58 PM
90NA300ZX
Sep 15, 2005 02:29 PM
futureZowner
Nov 26, 2003 10:02 PM
