L28e T
Old May 9, 2006 | 07:52 PM
blurrr's Avatar
L28e T
I have my engine out of my 78' Z and am ready to start doing the turbo kit. I have the turbo, turbo manifold, waste gate, bov, intercooler, and 82' ZX turbo ecu. I need some help to see were I should go next, what to buy, what to start putting on or taking off...EGR? PCV? Wiring Harness? ECT...Thanx
Old May 9, 2006 | 08:09 PM
So you're going to throw the turbo parts, on an N/A L28? A couple guys have pulled that off, but I guess as long as you have the 280Z dished pistons, you'll be ok. You'll need the L28ET wiring harness & some bigger injectors (as in L28ET / Z31T injectors), the turbo distrib, and the fuel pump module (unless you are going to hard wire the fuel pump). Also the L28ET AFM. Those are the basics. I know resources are limited, but it's always easier to start w/ a complete L28ET setup... then you don't have to search out all the damn parts, cuz you got em right in front of ya.
Old May 9, 2006 | 10:05 PM
jfairladyz's Avatar
might consider a later P series head as well to bring compression down closer to the L28ET level. Megasquirt is also an option if you can't track down everything you need to make the swap happen. That way you could use your existing distributor and could eliminate the AFM altogether.
Old May 15, 2006 | 06:58 PM
FairladyZS30's Avatar
i wanna more aboot this..can some one give me more info and a how to guide threw this?
Old May 15, 2006 | 07:07 PM
Exactly what are you asking? Putting a turbo engine in an N/A car, or trying to turbocharge an N/A engine? If you're wondering about the second, please stop.
Old May 15, 2006 | 07:40 PM
so what your saying is that its not worth it it right?
Old May 15, 2006 | 07:44 PM
This is what I said up above in this same thread:
So you can spend months (and a lot of money in shipping) looking for all the turbo parts you need, or you can get an L28ET and have all the parts you need, right in front of you. Which sounds easier?
Old May 15, 2006 | 07:48 PM
hmmmm...makes perfect sense..btw how do tell if a L28Et is blown...its cuz i found one and i dont really wanna buy a blown engine..
Old May 15, 2006 | 07:51 PM
If it runs... you know. If you're getting one from a junk yard, you won't really know how good the internals are until you open it up. But you can put a socket on the crank pulley to make sure it's not seized up.
So if you don't want to rebuild, I suggest looking for a running 280zx turbo.
Old May 15, 2006 | 07:54 PM
yeah but thats the best way...but i dont want a shell in my front yard......and im getting just the engine.....and i wanna know if you can use the relays from the n/a 280zx?
Old May 15, 2006 | 08:58 PM
jfairladyz's Avatar
make sure you can turn it over by hand at the least. Check compression as well. Check the sparkplugs for physical damage. Check oil for dilution with coolant. If that all checks out then you've pretty much got a solid base.
Old May 15, 2006 | 10:20 PM
sweet thanks...but can i use the ignition and relays etc.. from a n/a 280zx?
Old May 15, 2006 | 10:21 PM
You'll need the entire engine FI harness unless you plan on using a stand alone system.
Old May 16, 2006 | 07:36 AM
yeah i found the harness but i can use the n/a relays and ignition?
Old May 16, 2006 | 07:47 AM
yeppers.....
Old May 16, 2006 | 04:01 PM
sweet thanks alot nismo!
Old May 16, 2006 | 06:31 PM
oh yeah one more thing nismo...can i use a turbo AT on a manual?
T.Holland40
Aug 13, 2012 07:07 AM
Tsuka89
Nov 21, 2011 02:04 PM
michanic220
Sep 15, 2008 02:57 PM
980MAK
Oct 28, 2001 08:50 PM
