just a little wiring questions
Old Aug 13, 2009 | 10:28 AM
thetremendousti's Avatar
w0rld's l0ngest m0t0rswap
yeah I've searched zdriver, zcar and hybridz and although hybridz and google had alot of results, either the question wasn't answered or it was not my question so here goes.
Does the S30 have an in-line resistor for the tach? I guess I need one for my L28et swap and I just got to find it/get one! Along with that, is there any guide or any help as to how to get my:
thermostat and oil pressure gauge wired up to the L28et electronics?
The FSM's dont give enough information, just how to remove each gauge and the wiring schematics well....you know me and wiring
Old Aug 13, 2009 | 03:08 PM
skib's Avatar
This facepalm's for you!
what year S30 are you swapping it into?
[edit] nvm, the 74
Old Aug 13, 2009 | 03:11 PM
skib's Avatar
Dont know, but my tach is wired up like normal and works perfectly fine on my L28et
you dont, use the S30 oil pressure sender and stick your stock wire on it, use the S30 wire for your what Im assuming you mean water temp sensor since you said "thermostat"
Old Aug 13, 2009 | 05:52 PM
Okay, i just can't seem to find the resistor it must be really buried in the dash!!
So can i just splice my thermotime and oil pressure wire like so?
Old Aug 13, 2009 | 06:05 PM
flatblack's Avatar
T.I. Get on AIM...
Old Aug 13, 2009 | 08:48 PM
theramz's Avatar
I have a present for you...
The temp wire on the thermostat housing goes to the dash harness as it was oem. The thermotime switch goes to the ECU. The thermotime switch turns on the cold start valve. If you don't hook it up to the ECU it will assume the engine is stone cold and act accordingly. The tach reads off the + side of the coil and is inline with the transistor ignition box on the right kick panel. The tach resistor is on the same wire. I think it's the blue one.
Old Aug 13, 2009 | 09:21 PM
okay found the resistor just gonna run a wire from the neg to the resistor it was so far under my dash!!
Is it okay if I just splice open the white wire the water temp sw and run that to the C5 connector?
Nick Napala
FS: 300ZX (90-96)
Feb 7, 2014 01:55 AM
KoolMan
Aug 23, 2012 12:15 PM
300zgearhead
Apr 29, 2010 08:45 PM
wreckedj30
12
Feb 20, 2007 03:33 PM
NISMO LMR
Jan 24, 2004 11:23 AM
