gears?
Old Aug 21, 2006 | 06:51 PM
ThermalWake's Avatar
gears?
i have to either get my rear end rebuilt, or buy a new one. i want to buy a new one. what would be some good gears to go with. for all motor car. im thinkin 373-390's
Old Aug 21, 2006 | 09:42 PM
theramz's Avatar
I have a present for you...
Zack, your 2+2 might have the 3.9. if you remove the speedo gear drive from the trans you can check the color of the gear for the right ratio. Black is for the 3.9 rear. You can get the find the other codes from www.zhome.com.
Old Aug 22, 2006 | 02:38 AM
390 on a stock rear end?
Old Aug 22, 2006 | 11:43 AM
texasz's Avatar
I would not recommend this as the tranny or diff may have been replaced. To know for certain drain the diff and remove the rear cover then read the markings on the gears. This is the only sure fire way to know for certain.
Old Aug 22, 2006 | 08:54 PM
theramz's Avatar
If your not sure you can raise the rear of the car on one side only. Carefully mark the rotational position of the drive shaft and the wheel. Rotate thedrive shaft untill the wheel makes exactly one revolution. if you have a 3.9 then the ds will have turned almost 4 turns. 3.7 + 3 3/4 turns. To check the gears you will have to pull the whole thing to get the cover off because it is bolted to the mustache bar.
Old Aug 23, 2006 | 11:38 AM
theramz's Avatar
I looked up your car and the '79 2+2 came with 3.7 gears. The '81-'83 2+2 had the 3.9. Check it out, http://www.geocities.com/z_design_studio/
Old Aug 23, 2006 | 07:13 PM
do the regular coups of the same years have the same gearing? or does it have to be the 2+2
Z1andOnly
Apr 17, 2012 09:33 PM
ezramoore
Jun 9, 2007 07:07 PM
tt300z
13
Jan 21, 2005 03:50 PM
speedshade
Aug 31, 2004 10:24 AM
NISMO LMR
24
Jan 17, 2004 12:35 PM
