burning out fuel pumps and relays
Old May 12, 2004 | 05:15 PM
Z*Tech's Avatar
My guess is that someone either wired in a stereo that pulls wattage, and they used a ignition "hot" wire source that feeds the fuel pump and it's related circuitry or:
The car has a ground (battery -) problem that is causing too high of resistance.
Carefully inspect the battery cables, you need 4 gauge or better and if you have a ohm meter check the resistance between the negative battery terminal and a good body ground the meter should read low ohms. There needs to be a good ground connection to the body for the electrical circuitry to properly function.
Improper wiring attempts like you stated, rust at grounding points, etc. can cause the components to draw more current than they were designed for.
The 78 had a very good harness and should not be a problem.
Skully
Apr 22, 2015 09:20 AM
Bravenewme
Sep 24, 2014 11:45 AM
Matt K
Mar 26, 2007 11:13 AM
perfectindustry
Dec 7, 2002 08:06 AM
