The Build Begins... '71 240Z
Old Sep 18, 2014 | 06:30 PM
  #51
SlicktopS130's Avatar
Small update: Still can't insure the car because of brake issues... New booster, and still no resistance in pedal untill it nearly hits the floor, then the brakes grab. Also, i thought the car was burning oil but it turns out it's just running rich as hell. Budget is going dry.
Old Sep 18, 2014 | 10:08 PM
  #52
beg3yrs's Avatar
Sorry about the continuing issues. Budget is an issue for most of us.
Have you bled your brakes recently?
Old Sep 19, 2014 | 03:58 AM
  #53
Steve260Z74's Avatar
More importantly, are you sure you have the bleed screws on the tops of the calipers?
Old Sep 20, 2014 | 03:08 PM
  #54
Oh yeah, I've bled the hell out of the brakes. I think the shop sold me the wrong master cylinder (diagnosed by the HBZ guys) so I'm going to the scrap yard to see if I can find a used series 1 MC.
Old Sep 20, 2014 | 04:56 PM
  #55
zxguy1986's Avatar
Amazing amount of work, Slick. I envy your knowledge and skill. Please keep on keeping us updated thru to the finale!
Old Oct 12, 2014 | 10:48 AM
  #56
7d82adz's Avatar
Here's a better pic of the improved center console area.
Also pulled a door lock to send in and get a key made.
cool!... is it really that simple to fixing a lost key problem with a z? i have a 77 that has no key and was thinking i had to pull out every mechanism and igintion from a parts car and reinstall in order to have doorlocks and igintion again.. never thought about a locksmith using 1 lock to make a key.. very cool! this will save soooo much headache for me and enable the car to unlock the steering column without pulling stuff off of it. yay! ( i do feel kinda foolish for not looking into/ thinking about this option myself.. but thankyou for sharing)
Old Oct 12, 2014 | 03:04 PM
  #57
zxguy1986's Avatar
Gotta nominate Slicktop for numerous awards - just for the size of the projects he takes on... and follows through! Just awsum.
Old Oct 12, 2014 | 03:24 PM
  #58
[QUOTE=7d82adz;337640]cool!... is it really that simple to fixing a lost key problem with a z? QUOTE]
It wasnt too hard at all. For the door lock, all i had to do was remove the window crank and armrest and the panel popped right off. Ignition lock was too easy. I just removed the plastic column covers, unscrewed a few bolts, and the ignition assmebly came right off.
Thanks for the motivational comments, guys! Glad you all appreciate the work i'm doing!
Old Oct 13, 2014 | 07:12 AM
  #59
MOCIAP32's Avatar
Keep up the hard work. I'll be starting down the same road in a few weeks, after I get my '70 240Z back from the "junk yard". It will be in even worse shape.
I knew that car inside and out when I owned it from 1974 to 2000.
skyladyz
Sep 22, 2014 02:17 PM
alexcampos240z
Jul 10, 2012 03:53 PM
FubarI33t
Jun 5, 2010 07:56 PM
emo236
May 27, 2004 01:54 PM
