Boost leak/smoke test TB seal
Old May 13, 2016 | 02:43 PM
Mackay10's Avatar
Hope I'm posting in the right area here.
78 280z l28et (z31 ecu and maf recent)
I smoked the entire intake after the MAF and found good size leakes on both sides of the throttle body at the shaft seals. Have any of you guys replaced these and/or know where they can be be found? (60mm throttle body). Thanks
Old May 16, 2016 | 09:46 AM
They are bearings no? If it's leaking, then have the seals been blown out?
Old May 16, 2016 | 02:47 PM
theramz's Avatar
I have a present for you...
Those seals are meant to keep dirt out not boost in. You need a tb meant for boost.
Old May 16, 2016 | 07:05 PM
Mackay10's Avatar
I'm pretty sure it is the MsA TB. There is slight side to side play but I'm not sure if it has bearings or bushings with possibly seals on the outside. Maybe it's not making a difference in performance just didn't know if anyone had replace them due to a boost leak issue.
jalexquijano
Jan 19, 2016 03:24 PM
hoov100
Mar 7, 2010 02:51 PM
Niku-Sama
Aug 29, 2008 08:23 PM
duowing
Dec 19, 2007 09:26 PM
zfreakracing
22
Feb 17, 2004 06:33 PM
