Boost this
Old Jun 3, 2011 | 06:00 PM
theramz's Avatar
I have a present for you...
Boost this
Made up some stainless steel headgaskets. 1.5 mm thick, flat within .0005
Old Jun 3, 2011 | 07:05 PM
Absolute sickness! So you are going to have these mass produced? Price?
Old Jun 4, 2011 | 11:58 AM
Fast240Z's Avatar
ohhh sexy, I'll put it on my n/a...
Old Jun 6, 2011 | 06:58 AM
theramz's Avatar
I made 4, one for you at a special price. pm me
Old Oct 10, 2011 | 12:19 PM
Just curious.... are those machined or water jet? Does flat to .0005 matter as long as the head and block are true?
Old Oct 10, 2011 | 01:46 PM
Nismopu's Avatar
Thats deffinitely just water jet or laser, most likely water with the look of the edges. Curious, how do you plan on keeping these from moving? Copper sealant? What kind of block and head finish is recommended for a SS HG?
Old Oct 10, 2011 | 06:38 PM
theramz's Avatar
The .0005 flatness does not matter that much, that's how it comes from the mill. However, if you have irregularities greater than that in a small area there could be problems under high boost around the combustion chambers. The head and block together should be flat within .002 overall with no dips or bumps that can't be sealed with copper spray. In addition the head should be torqued down with the block on a bench not an engine stand. The copper allows the block and head to move under temp changes without losing seal.
And yes, it's done on a waterjet.
Old Oct 10, 2011 | 06:43 PM
theramz's Avatar
The gasket has approx 8 rms so your head and block need to be 32 -64 to allow the gasket/sealer to move enough to follow temp changes.
VanBruno
Nov 2, 2014 10:16 PM
lilotanni
May 10, 2011 04:33 PM
1SIKZ
Mar 12, 2006 11:39 AM
jtmny1999
Apr 3, 2003 07:40 PM
DVSTT
Oct 18, 2001 06:09 PM
