77 280Z 2+2 clutch? shifter?
Old Dec 8, 2009 | 08:50 AM
luckyZ13's Avatar
I start her up and put in gear and no go. I can shift into any gear WITHOUT pressing the clutch in! Any ideas? Ran great yesterday with no probs.
Old Dec 8, 2009 | 11:39 AM
With the motor running you can pull the shifter ALL THE WAY into all gears? And no grinding? No moving? If so you've got major problems...
However, I don't think you are actually able to do that.
Have you checked the fluid level in the clutch master cylinder? I think you'll find that it's empty (call me psychic).
Old Dec 8, 2009 | 02:26 PM
luckyZ13's Avatar
checked fluid and it was a little low so i filled it up but still nothing. No grinding or movement. sounds impossible I know!
Old Dec 8, 2009 | 02:32 PM
Next step would be to check the slave cylinder for movement when you push the clutch petal in ( 2 man job unless you have super long arms and neck )
Old Dec 8, 2009 | 02:55 PM
BlueKitsune's Avatar
Intrawebz Wizard
IF thats the case Your do have major problems. You could have a broken clutch/pressure place Or a broken input shaft on the tranny. OR! (if you lucky) The slave cylinder might be stuck all the the way out so the clutch isnt engaging but thats a long shot at best.
Old Dec 9, 2009 | 02:09 PM
theramz's Avatar
I have a present for you...
Hmm, been popping the clutch have we? The clutch disc may have come apart or the input shaft is broken. Could even be the shift rods are slipping. Try neutral to reverse with the engine idling (clutch out). Like he said, fork hang-up. Have someone pump the pedal and you observe the fork movement on the trans.
lovemyz
May 17, 2010 10:58 PM
Jared
Jan 5, 2010 06:39 PM
yves280zx
Dec 16, 2006 01:39 AM
jtmny1999
Jan 18, 2004 09:04 PM
