71 260Z flashers
Old Sep 19, 2004 | 06:07 PM
colin1mac's Avatar
71 260Z flashers
i have a 71 260 and the four way flashers work but the turn singles don't work niether do the parking lights so i was wondering if anyone else had this promblem if so please respond
Old Sep 19, 2004 | 08:54 PM
theramz's Avatar
I have a present for you...
The flashers are on a seperate fuse circuit. Check your fusebox for melted terminals and go from there. The reason they melt is the connector plugs in these old cars get corroded which increases the resistance which causes the fuse to blow. People put bigger fuses in and something else has to blow- the wiring! Get some contact cleaner from RadioShack and as you trace the loom, unplug and spray the connectors. You will be amazed at how much better everything works.
Switchtr3
Oct 16, 2012 04:47 PM
BlakesZX
Mar 13, 2012 11:36 AM
Blue_streak
Dec 16, 2010 11:03 AM
rxKaffee
Oct 21, 2007 09:31 PM
Airpilot16
Jun 27, 2003 01:24 PM
