71 240Z Partial throttle misfire.
Old Nov 13, 2012 | 07:45 PM
hls3010033's Avatar
Question 71 240Z Partial throttle misfire.
So here's the story. While under partial throttle I am noticing a terrible miss, usually happening at low revs (<3000) and only when the engine is at operating temperature. Almost feels like I am running out of fuel however when I fully open the throttle it goes away almost instantly. Any Ideas?
Details:
Stock L24 with E31 head.
Timing: 12 deg adv. @ idle
Points gapped @ .017
Accel E-Coil
NGK Plugs
Carbs tuned roughly 3 months ago.
Dampers filled with straight 30 wt oil
Valves adjusted 4 months ago .010 intake .012 exhaust
Thanks in advance!
Old Nov 13, 2012 | 09:16 PM
victor askew's Avatar
Is this dual point or single point system you have.? If dual are both sets of points gaps still matching ? Have your points moved from where you set them up?
Vacuum leak on or near the intake manifold fitting/ hoses?
I would run the car in a dark garage and check the dist cap for cracks by looking for flash/ light visble to the outside.
Chk the coil/ dist cap and all spark plug wire connections.
Does the ballast have a crack in it? Replace it if req'd.
Good luck with this.
Old Nov 14, 2012 | 02:32 PM
hls3010033's Avatar
Problem Solved. So apparently I have neglected my ignition system and my points gap was only .012 which in-turn fried my Accel E-Coil that was less than 6 mos old. Luckily, I work at a local parts house and picked up a Flamethrower coil, a set of Accel spiral core 8mm wires and a new set of NGK plugs for $60. Swapped it all out at lunch today and the car runs amazing, she has a willingness to rev that I have never felt before. Pulls hard in 4th from 1200 Rpm with no complaints.
jalexquijano
Jul 29, 2015 09:08 AM
FullTiltZX
Jun 19, 2014 04:48 PM
nuzxowner
May 17, 2005 08:48 PM
