'82 280ZX Non-Turbo Partial Part Out
Been working on my recently acquired 82 ZX and in short i am taking a bunch of stuff out to make room for many new parts and upgrades. I need to get rid of what has been removed and about to be removed to make room for the incoming stuff.
Shipping is not included on any prices and if you live in Reno, NV area i can do local pickup.
I'm trying to get the engine and trans out together because its cheaper to ship them on the same pallet and to be honest i don't want to get stuck with this automatic transmission lying around so basically handing it away with the motor. If you need a motor trans for your rolling shell here it is!
1) L28/P79 Engine and Transmission will be sold together ABO $1500
Engine Compression 1-6 165/165/168/170/168/170
Transmission shifts smooth, Trans Cooler lines included, Starter Included,
Wiring Harness for Engine/Trans included + ECU, Alternator Included, Engine Mounts, Mechanical Fan/Clutch
(Some hardware was missing when i purchased the car but i can give you what was removed)
2) Cruise Control Cable Unit $ Make Offer
3) Washer and Overflow Bottles $ Make Offer
4) Evap Canister and another canister i cant remember the name of that sits right under the hood light (it has two vacuum modules on it) $ Make Offer
5) Skid Tray, Exhaust Shields (tunnel Locations), and Rear Tunnel Brace $ Make Offer
6) Lower Grille Insert Bar style...Has a few cracks can send extra pictures if interested. $ Make Offer
7) Factory Bump Style Front bumper center section and two side pieces. (Crash Bar and Lights not included)
8) AFM, Ran rich when i got it and adjusted the AFM unit leaner and it worked just not verified with an accurate Wideband. $50
9) Air Intake Assembly from Intake through Air Cleaner Snout minus the AFM unless you want that as well then its price will be added. $50
If you have interests on any of these other items i'm about to take out just let me know. I don't have a normal work shift so if your interest in one particularly, i can put it as a priority removal with exception to carpet because i have to basically remove everything to even get at it.
Items To Be Removed:
1) Instrument cluster gauges function properly but can't tell if the engine light is working like its supposed to.
2) Center Dash 2 Gauges working oil pressure/volt meter and Clock turns on but i didn't take the time to figure out how to set it because i knew it was coming out.
3) Both Seats which work and are covered but not the prettiest or most comfortable ZX seats I've had the pleasure of sitting in.
4) Automatic Shifter Assembly
5) Radio Din Insert for Lower Dash Valence
6) Ash Tray coming out to make room for custom paneling
7) All Interior wiring harness's will be removed for 100% custom re-wire
8) Side marker lights front and rear
9) Power Steering Pump and Pump Lines
10) Carpet (black in great condition) and Trunk Carpet (Black great condition as well)
11) Differential and rear axles
12) Fuel Tank (Without Filler Neck)
13) Fuel Transfer Lines (the ones that run along side the drive tunnel to feed the engine bay)
14) Pedal Assembly Gas and Brake.
15) Brake Booster/Master Cylinder
16) Front Brake calipers(i still need the rears for the emergency brake functions so for now i wont be letting those go)
17) Rear Bumber Factory bump style and
If you have questions about parts i didn't mention i may have more i just forgot to bring up so ask and i shall answer with what plans i have for questioned parts.
-Alex
-Alex
Last edited by FullTiltZX; 06-19-2014 at 04:50 PM. Reason: update front bumper inclusions/exclusions
leehammy
FS: 300ZX (90-96)
03-06-2013 10:25 AM
borini63
235
09-20-2012 12:47 AM
