71 240Z Partial throttle misfire.
So here's the story. While under partial throttle I am noticing a terrible miss, usually happening at low revs (<3000) and only when the engine is at operating temperature. Almost feels like I am running out of fuel however when I fully open the throttle it goes away almost instantly. Any Ideas?
Details: Stock L24 with E31 head. Timing: 12 deg adv. @ idle Points gapped @ .017 Accel E-Coil NGK Plugs Carbs tuned roughly 3 months ago. Dampers filled with straight 30 wt oil Valves adjusted 4 months ago .010 intake .012 exhaust Thanks in advance! |
Is this dual point or single point system you have.? If dual are both sets of points gaps still matching ? Have your points moved from where you set them up?
Vacuum leak on or near the intake manifold fitting/ hoses? I would run the car in a dark garage and check the dist cap for cracks by looking for flash/ light visble to the outside. Chk the coil/ dist cap and all spark plug wire connections. Does the ballast have a crack in it? Replace it if req'd. Good luck with this. |
Problem Solved. So apparently I have neglected my ignition system and my points gap was only .012 which in-turn fried my Accel E-Coil that was less than 6 mos old. Luckily, I work at a local parts house and picked up a Flamethrower coil, a set of Accel spiral core 8mm wires and a new set of NGK plugs for $60. Swapped it all out at lunch today and the car runs amazing, she has a willingness to rev that I have never felt before. Pulls hard in 4th from 1200 Rpm with no complaints.
