70 240z SU Issues??
Old Jan 4, 2011 | 04:49 PM
ZChief's Avatar
Question 70 240z SU Issues??
The car bogs down and stalls right around 50 mph (4rth gear). It'll crank right back up and runs great up until that point, but I cannot quite figure out what the problem is. I suspect it's a carb issue, but if so, I cannot seem to tune them correctly. Do any of you have any suggestions?
Old Jan 5, 2011 | 06:11 AM
theramz's Avatar
I have a present for you...
Check your fuel filter. Then your fuel pump. Next your float/bowls. Sounds like it is running out of gas.
Old Jan 5, 2011 | 06:45 AM
BlueKitsune's Avatar
Intrawebz Wizard
I had a similar issue with my 72 SUs. Turns out the throttle shafts wore out and was leaking a vacuum behind the needles. After driving see if their wet with fuel on the outside if they are the bushings and maybe the shafts themselves need replaced.
Old Jan 5, 2011 | 07:20 AM
ZChief's Avatar
70 240z SU Issues
Fuel filters are clean and have been replaced (I have one up front and I added one near the tank in the back). I'll double check them again just to be sure, but I think I might need to go through the carbs again. I was hoping not, but their rebuild is several years old (car has been doing a lot of sitting while being restored). Good suggestion about the throttle shaft issue. I'll check it out also.
Old Jan 5, 2011 | 11:00 AM
Intrawebz Wizard
Ya if it would hold a tune the throttle shafts are probably your issue then.
Old Jan 8, 2011 | 05:44 AM
ZChief's Avatar
Thumbs up 70 240z SU Carb Issues
OK Bluekitsune, that's the direction I'm going to go. A Z Therapy rebuild kit and throttle shaft bushings.
Thanks for the help
7d82adz
Jul 5, 2013 06:09 PM
serialbeater
Jul 10, 2012 06:54 PM
SwitchAZ
Jun 4, 2012 01:35 PM
hoov100
Apr 24, 2006 10:59 PM
emo236
Mar 23, 2005 08:36 AM
