280z fuel leak, don't know what to do..
Old Sep 17, 2012 | 09:47 AM
kevum's Avatar
I just recently bought a 280z and everything was great until I started to smell fuel while driving it. So I popped the hood and there is a leak on this rubber hose coming from the fuel rail to the injector. I just don't know the name of the part or if I have to buy a whole new injector or what..
Old Sep 17, 2012 | 09:56 AM
It's just fuel injector hose. Fairly common for 30+ year old fuel hose to get brittle and crack / leak. Just yank the rail and replace all the hose (you can buy fuel injector hose for like $2 - $3/ft at your local parts store.
It's kinda time consuming to get the rail off, but not complicated. Make sure you download the FSM from XenonS30
Old Sep 17, 2012 | 10:05 AM
kevum's Avatar
ok thanks man, thats what I thought it was. Just makin sure. I really appreciate it.
Old Sep 24, 2012 | 06:50 PM
zero's Avatar
Once you get the injectors off, the pintle caps will be very brittle so be careful. Replace all the injector hoses with the right type of hose. Split the old hose with a razor down to the metal collar. Take a soldering iron and burn through the hose left behind the collar you cant cut through, and yank the hose off. Reuse the collars when installing the new hose.
Old Sep 27, 2012 | 03:39 PM
kevum's Avatar
1976 280Z FUEL INJECTOR HOSE REPLACEMENT
detailed how to if anyone else has this problem.
JohannB
25
Sep 14, 2013 10:53 AM
eZdoesit
Aug 12, 2011 07:17 PM
JohannB
Dec 9, 2006 01:14 PM
Carl's Z
Oct 14, 2005 09:27 AM
cookiecutter
Jun 8, 2003 10:32 PM
