280z distributor?
Old Sep 21, 2007 | 07:28 PM
280z racer's Avatar
280z distributor?
I just got a 77 280z and it needs a distributor, what one do I need to go find?
Old Sep 21, 2007 | 07:45 PM
280z racer's Avatar
so what I found is that I Should use a 81-83 zx distributor with the E12-92 module, is the best?
Old Sep 21, 2007 | 08:17 PM
or... you could use the stock one...
Old Sep 21, 2007 | 08:25 PM
280z racer's Avatar
The distributor and starter are gone, can I use the starter off a zx to?
Old Sep 21, 2007 | 08:36 PM
Indeed....
Old Sep 21, 2007 | 08:40 PM
280z racer's Avatar
Yes indeed.
Old Sep 21, 2007 | 08:42 PM
Are there other parts missing?
Old Sep 21, 2007 | 09:03 PM
280z racer's Avatar
The battery.
Old Sep 22, 2007 | 12:21 AM
i got a 82 distributor with ignitor ion it for sale if yah wants.
used of coarse but cam off a good running car
Old Sep 22, 2007 | 11:19 PM
280z racer's Avatar
I put the starter and distributor on it tried to start her up and she would not start. Then I found that the fuel pump was not on so I ran a power wire to it and it was working. So then I tried to start it agine and she would not start even with starting fluid. So then I tested the fuel injectors for power and there was none. so what dose everyone think?
Old Sep 23, 2007 | 11:40 AM
What did you use to verify no power to the injectors?
Old Sep 23, 2007 | 09:54 PM
280z racer's Avatar
a diod light.
Tonylsg
Oct 2, 2012 07:18 AM
Blue_streak
Aug 21, 2011 06:33 PM
Blue_streak
Jul 25, 2011 07:47 PM
Midgetman
Jul 10, 2011 12:55 PM
speedgato
Jul 16, 2002 04:49 AM
