240z extra horsepower
Guest
Posts: n/a
I have a 240z that I just got running. I am hoping to increase the power. Right now it is stock except a dual webber carb.
Does anyone suggest a header exhaust set?
What other recommendations do people have to increase the power, short of swapping out the engine.
Zover
Zover
Zover
Zover
POS header
Here is a picture that shows where it touches on the E46 manifold. You can see the blistered paint (1200 degrees+). I changed to the N36 manifold to give about a 1/4" clearance, still a little to close.
I ran 2 1/4 pipe to a 18" supertrapp too and I must say it sounds fantastic! Like a V8 with a mild cam at idle and at high rpm a sound that only a Z can make. I am going to bring a tester from work to check on the amount of heat radiated into #3 intake compared to the others. Will post results.
P.O.S. header
Brought home an infra-red thermometer with a laser pointer. I drove home hard to get it good and warmed up. Poped the hood and turned the idle screw up to 2500 rpm. Checked all the intake tubes at various places all around and found that they all run between 170 on top to 200 on the bottom side except #3, 240 degrees! I'm going to wrap the header and the intake in that area on all six.
wow.....
thats a disturbing piece of data, thanks for the info... i have one of these headers im waiting to put onto my car, and now i will definitely make sure i wrap everything well first... we might should try to find a way to make this information more available than it will soo be, buried in this thread.....
thanks again
thanks again
Zover
Zover
solcalidus
Sep 30, 2007 08:36 PM
