240z
240z
not sure where to post this? need some opinions though do you think it is worth the price? CAD
it would be my first Z, also a project for over the winter/spring
Description -Original Straight 6
-Aftermarket Headers
-Custom Paint Job (chips here and there)
-Shaved Rear Bumper
-Molded "whale tale" spoiler to hatch
-Lowered
-New Floor boards, drivers & passangers side
-Newer Carpet
-Front fascial with grill (not installed)
-Runs Good
-low serial number, one of the first 240's made
The Bad
-Cracked dash
-Torn bottom seat on drivers side only
-Car sat for about 2 years (not a bad thing just a side note)
-small rust areas
-needs some TLC
-transmission needs work
Price: $2,300
-Shaved Rear Bumper
-Lowered
-Newer Carpet
-Runs Good
The Bad
-Cracked dash
-small rust areas
-needs some TLC
Price: $2,300
not a bad looking car, be careful about rust and such. What may look like a little rust could be some serious cancer. I'd check under the battery tray, the doglegs, under the back hatch, the spare tire wheel well, and the floorboards.
As for it being a early 240Z, it does have the side emblems that indicate that age. Check to see if it has vents below the glass on the rear hatch, and also check the VIN and post it here to make sure it truly is a early 240Z.
One thing that I'm always curious. What does it mean when they say the car needs TLC? I mean, I know what TLC stands for, but what do they mean by it? Do they mean it's gonna need work, or it has problems that are going to need to be worked out or what? I'm just curious as to what you might want to expect from a car needing TLC.
depends on the seller. I'd say my Z needs some tlc (rust spots, not too bad, but need to be fixed), new paint job would be nice, e-brake needs to be tightened, new seats and headliner would be nice too.
Guest
Posts: n/a
i like your car
