Tire rubbing front fender: help
Old Jul 30, 2004 | 01:18 PM
Jerry2636's Avatar
Mine would rub but the last guy cut away some of the front valence. Poorly done but it worked.
Old Oct 18, 2004 | 06:51 PM
myxtaz's Avatar
I just repaired mine as I am getting ready to paint and have been doing the body work. I am changing tires and have lowered the front so I will see when the engine is back in if it rubs. this vallance was bent and part of it was rolled up from catching on the tire. I am just going to modify mine to clear . I appears that it will only be slight amount of trimming to clear , 3/8'' at most and just from the corner.
Old Mar 9, 2009 | 08:07 PM
nick's Avatar
nick
I bought my 71 new. At the break in service i added 1 inch wider wheels to the stock tires and the right front started rubbing. 38 years later it still doing it when there is a small bump while turning right. I just took a rubber hammer to the inside lip of the right fender valance and that took care of everything except the aforementioned rubbing. Even after I went up a width on the stock tires.
Old Mar 9, 2009 | 10:49 PM
dude, this thread is 5 years old. (will i really have been here 4 year in September?)
Old Jan 31, 2011 | 05:46 PM
nick's Avatar
the car is in my garage i haven't driven it enough to remember if it still did it after rebuilding the rack and pinion and re centering it. But before it gets a repaint it would be nice to know if any one ever figured this out. it's been rubbing for 40 years. You know you're getting old when the car you bought new is an antique!
Old Feb 1, 2011 | 09:01 PM
Racer Z's Avatar
Ok, so I'm a few years to late. That's just the story of my life.
We have run that size tire on the dealer upgrade dish mags without any rubbing. We also run 225/50x15 on 15x7 without any rubbing.
I suggest that something is bent or damaged. Check everything. Wheel bearings; alignment; (yes check the non-adjustable camber/caster); check for bent body work/panels; check for signs of crash damage;
Old Feb 1, 2011 | 10:21 PM
^ Hey at least you dug up a thread, instead of starting a new one. And it shows the search function was used. So all in all, I would say it is still quite useful.
s30zdriver
Dec 29, 2014 11:14 AM
John Haag
Jan 11, 2012 07:54 PM
YourChaosIsntMe
Jul 28, 2011 03:40 PM
sticky280zx
20
Jan 30, 2008 10:15 AM
lugerz
FS: 300ZX (84-89)
Jun 2, 2005 07:19 AM
