switching radio
Old May 7, 2005 | 02:54 PM
mitch0331's Avatar
switching radio
i recently purchased a 71 240z and want to change out the radio. i'll be keeping the orginal parts and fabing a new face plate. is there some trick to removing the fan speed control ****? i thought it would just pull off but it won't budge. anyone have any insight?
Old May 7, 2005 | 04:03 PM
Fast240Z's Avatar
there is a screw right under the fan control ****. Why do you want to take out the climate controls? if you just want to change the deck out, then the stock deck should slide right out, provided you have the right "keys" for it. If you look on each side of the deck, it is going to have a slot on both sides, for a flat piece of metal to slide into, which will release the deck from it's brackets, and it'll slide right out.
Old May 7, 2005 | 04:33 PM
mitch0331's Avatar
the whole console face plate needs to come off in order to take out the radio. the radio face plate comes off with the two screws at the bottom. the radio itself sits behind the main console face plate which is held on by two additional screws at the top (either side of the light). when all four screws are removed the console face plate is still held on by the fan speed control ****.
Old May 10, 2005 | 03:01 PM
mitch0331's Avatar
i removed the ***** but the console face plate seems to be held on by something behind the slide controls. anyone have any thoughts on whats keeping it on?
lilmike81888
Apr 27, 2012 12:18 PM
Darkmann
Jun 19, 2011 09:44 AM
chall3440
Jul 21, 2008 06:09 AM
ZXDude90
Oct 2, 2004 12:20 PM
Ramen Sama
Apr 11, 2003 11:01 PM
