Removing the rear strut assemblies: 76 280Z
Old May 7, 2004 | 08:13 AM
Question Removing the rear strut assemblies: 76 280Z
What is the trick to getting the rear struts out? I know I have to remove the whole hub and everything. I got the locking pin out on the lower a-arm connection but that steel rod with the two large nuts won't budge. Do I need a press or some special tool to get it out?
Old May 7, 2004 | 09:26 PM
theramz's Avatar
I have a present for you...
It' really tight and corroded in there. I used a piece of steel bar stock, drilled a hole in the end to allow it to fit over the threads. I wet everthing down with penetrating oil and the next day was able to drive them out. I still managed to booger the threads on the pin a little but I repaired them with a small triangle shaped file. MSA sells new ones for $23 each.
Old Oct 17, 2004 | 03:45 PM
myxtaz's Avatar
Talking
I have a spindel pin puller! It will pull the pin and save it from damage so it can be reused saving some cash . No pounding and it doesent require the removel of the suspension part from the car. Makes it a easy couple of hour job and if you are going to install ureathane bushings , you can use the tool to spread the part the 1/16'' to allow everything to slip togither. I have it to loan , I just require you to pay the shipping cost both ways and a promise to return the puller when the job is done . Contact me if you need it. If you have pounded on the old pin already this puller WILL NOT WORK . For and example of shipping cost . I shipped it to the San Francisco area from Portland Or and it was $8.00 each way.
Old Oct 21, 2004 | 02:54 PM
Daeron's Avatar
i managed to replace the struts on the rear of my 75 by just removing the suspension A-arm from where it pins in to the center cross-member.. i then pivoted the whole strut assebly with wheel hub still intact down and managed to get the strut out of its tower.. but as i recall it required some interesting shifting and fenagling...... but imanaged to do it. i had to remove my halfshafts too, but i had to replace one of them at the same time so it was all gravy. if you do it this way it might not be a bad idea to inspect those halfshafts real thoroughly, and replace if theyre old, and if you can. kinda like doing a water pump when you do a timimng chain, just cuz youre there already, yanno?
Old Oct 26, 2004 | 07:57 AM
ok guys.... ya, about 5 months ago when I did this I just disconnected the half-shafts and the parking brake cable. I was able to compress the strut with my hand and get the thing to barely clear the fender and swing outward. The first rear strut took 4 hours to figure out. I did the rest of the car in probably 2 more hours of work. The front was much easier.
Since then I have read that removing the inner connections on the lower a-arm is easiest. (as Dareon and Kenneth said) But, one day I'd like to replace all those bushings on the Fairlady... that won't be fun.
Old Oct 27, 2004 | 02:30 AM
Daeron's Avatar
its a little off subject, but thats a little peevish; i hate it when someone replies to a problem post that someone else made like six months ago and brings it to the top of the list.... because here i was telling bleachzee how to fix the roblem he's already dealt with, because i was too lazy to look at the date.. i guess we all get peeved when other peoples shortcomings bring up our own shortcomings..
eh, food for thought.
danozgriff
12
Mar 31, 2014 09:04 AM
LemonHead
Apr 2, 2012 08:01 PM
Turbo Biscuit
Mar 29, 2012 07:37 AM
v0va
Mar 25, 2007 02:57 PM
CaptainZ
Jan 10, 2005 10:55 AM
