Drivers side hinge detent roller - 77 280z - loud pop when door opened
Old Oct 2, 2011 | 03:05 PM
jkeese01's Avatar
This has been an issue for years. The drivers side door makes a loud pop when opened. The detent roller has a indention carved into it on one side from wear.
I can rotate the roller so the indention is on the backside. This works for one time, then the indented side moves back to the front, and the door starts making the loud pop again when opened.
This article has some great information:
Rebuilding Door Hinges on 1st Generation Z Car
http://atlanticz.ca/zclub/techtips/b...inge/index.htm
but the author found "some lower hinges that had the return springs and roller stops in place". He rebuilt the hinges using new bushings and pins and seemed to use existing detent roller.
Has anyone fixed their worn detent roller?
Thanks,
Jim.
ANSWER:
These are the parts needed to rebuild the hinge: (worked on 240z)
Dealer Parts:
Nissan Pin ----- Part# 80406-V5002
Nissan Pin Bushing ----- Part# 80410-01G00
Roller not available from Nissan.
Or Non-Dealer Source:
At Advanced Auto: the bushing and pin kit is Dorman part # 38397.
At McMaster-Carr: Press-Fit Drill Bushings (the roller) ----- Part# 8491A202 from mcmaster.com
These Pins will not work as the Roller Pin. Try to reuse the one on the car:
Image of Roller Pin and Stop Arm Pin (click to view):
Instructions for rebuilding the door hinge:
Old Oct 2, 2011 | 09:24 PM
theramz's Avatar
I have a present for you...
You can weld it in place or remove the hinge and replace it or try to get someone to make a new roller. The bolts are behind the ecu/kick panel. You should be able to get it out without removing the door.
Old Oct 3, 2011 | 06:26 PM
jkeese01's Avatar
Thanks TheRamz, some great options. Nice to hear that it can be removed without removing the door. Been looking around, but haven't found a replacement. If I can't find a replacement, or get a roller made, will have my uncle weld it.
Another idea someone gave me was to slip a bronze flange over the roller. The lip on the flange will help keep it from slipping off. I'll try this first and post the results.
Old Dec 21, 2011 | 10:56 AM
BOOSTINMYZ's Avatar
Thanks for the info! Having the same sound on my turboz.
DeathByNissan55
Dec 13, 2020 03:42 AM
Pete DePalma
Mar 28, 2013 05:29 PM
Utah Hawkeye
Jul 19, 2012 07:30 PM
1982zxt
Jan 6, 2006 09:53 AM
kewlcat
Oct 26, 2001 09:36 AM
