Cruise control delete?
Old Aug 13, 2010 | 12:45 PM
I've decided a one hour search on a topic is long enough if I can't find something to ask for it. I'm sure it's been posted somewhere but I can't find it.... do we have a thread on the cruise control delete somewhere?
Old Aug 13, 2010 | 01:24 PM
I don't think there's a write up for this as it's pretty simple:
-Remove cruise control actuator unit
-Disconnect cable from throttle linkage
-Plug vacuum lines
-Going the extra mile would include removing the cc box and relays from under the passenger seat.
Done!
Old Aug 13, 2010 | 02:20 PM
MurphyEF's Avatar
You want yours gone, and I want mine working. Lol. It's pretty simple to remove, like Nismo said.
Old Aug 13, 2010 | 03:11 PM
Cruise control is the next step before sleeping in your vehicle. I definately didn't get the ZX to sleep in (although I must admit there have been a few nights.....).
I never use mine, its not currently working and I've got less than zero desire to get it going. I can use the room on the fender for another fuse block and clean the engine bay up.....
Old Aug 13, 2010 | 03:28 PM
I actually removed my cc and a/c a while back thinking "pft... I don't need this stuff!"
These days I do want comfort! I'll be putting them back in this fall.
Old Aug 13, 2010 | 07:11 PM
KHCreason's Avatar
I always forget i have cruise control, even on my grand prix lol Looks like I'll be taking mine out too! in fact, I think its a great place to mount my ignition
Old Aug 13, 2010 | 07:50 PM
The 79-81 cruise control is worthless... just on/off.
The 82-83 has the modern accel/decel switch added.
My 81 has an 82 complete wiring harness...
Old Aug 13, 2010 | 07:53 PM
KHCreason's Avatar
I kinda toyed with the idea of robbing a newer grand prix of its ambient light sensor from its dash and its light **** from the steering column, and hook it up to the datsun to have auto headlights and a newer looking non POS switch, but it would have to have the cruise control switch with it as well... think they are remotely riggable?
Old Aug 13, 2010 | 08:02 PM
early CC is a push button lol which I actually like myself. but I removed my CC when I was cleaning my engine bay. never felt the need to put it back in as I never use it sept for once in a blue moon
Old Aug 13, 2010 | 08:32 PM
Hmmm.... the cruise control on my '81 was the same as my '83. Maybe because my '81 was a Canadian version it had the newer cruise or maybe an '81 1/2? Everything else was Series I like the tail lights, hood, exhaust exit, exterior pillars, bumpers, etc...
Old Aug 14, 2010 | 06:03 AM
yes fricfrac, you have an 81.5 then. my 79 never worked, i tried so hard, swapped parts. it never would so out it came. i drove to cali and back, never really wished i had it. to busy swerving in and out of traffic anyhoo.
Old Aug 14, 2010 | 10:47 AM
The only time my cruise control worked. Was in my '81, the first year I had it. After I changed to the 130 speedometer. It never worked again. I hardly used it anyway. It is a 5 speed sportscar. Don't need no stinking cruise control. lol
I can see how a/c would be essential, especially down here in the desert. But the cruise would take the fun out of driving. If I had an automatic, like my Neon is. Cruise is handy sometimes. But in a stick, it's kind of pointless in my opinion.
Old Aug 14, 2010 | 04:09 PM
Just an FYI if you do ever want your cruise control to work again, you just need to swap the 130mph speed sensor on the back of the speedo to the 85mph sensor.
I finally fixed mine last year so my voice warning system would work again:
Old Aug 14, 2010 | 06:14 PM
all the canadian cars use the top sensor as all of ours go to 220kph (130mph) i want frank to send me a 300kph unit from europe
Old Aug 15, 2010 | 02:28 PM
Hmm..okay, they look quite different. So how would I install the 85 mph one, on the 130 mph? I am sure I could figure it out. And does it really have the voice warning system work again? I didn't even realize that. Very interesting, and thanks for the information.
Old Aug 15, 2010 | 09:58 PM
Yep, if you still have the 85mph speedo, you'll see how the speed sensor is attached. Just remove the one from the 130mph and install the 85mph one.
The speed sensor is needed for some of the voice warnings: door open, e-brake on, and also controls the MAF burn cycle for my Z31T ecu / MAF setup.
Old Aug 16, 2010 | 10:28 PM
Very cool - didn't know about the speed sensor. Where is it located? I swaped my US Digital 85MP for a Canadian 130 MPH analog but never read anything in the swap info about the sensor - great info (as usual) NismoPick +1
Old Aug 17, 2010 | 09:56 PM
right behind the speedo, next to the cable
Old Aug 17, 2010 | 10:52 PM
Aha! Ok so I swaped it out with the speedo unknowingly because it's already attached. That's probably why they don't mention it in the speedo swap threads because it already gets swapped unless you mess with it.
Good to know - thanks guys!
harnest
Jul 15, 2010 11:38 AM
cblevons
Aug 21, 2005 01:44 PM
akshon_muZik
May 18, 2005 09:36 PM
kd5izq
Oct 8, 2002 04:06 PM
DMT84T
Jan 3, 2002 09:04 PM
