280ZX - both power windows stopped working at the same time
Old 01-26-2009, 06:25 PM
If both your power window switches lose power it could be the power window breaker that has failed.
It is bolted behind the metal just above the fuse panel. Remove the plastic trim around the fuses, the under dash panel, and then unbolt the wiring harness plugs from the car. You can then unbolt the bracket just above the fuses and squeeze the fan timer and window breaker out and around.
I replaced mine with a used one.
Once working, the windows were slow and showed signs of dragging. They were probably tight from not being used often. I took off both door panels and lubricated the power window slides inside the door.
Bleach is offline
linkovich
12-31-2014 01:47 PM
gt46l
10-17-2014 06:51 AM
1980datsunz
08-17-2013 03:46 PM
Turbo86
05-23-2006 03:26 PM
Quick Reply: 280ZX - both power windows stopped working at the same time
