ABS unit on '93 300Z Convertible
I have been searching way too long trying to find the ABS actuator on my convertible. I have read dozens of post and read every word of the repair manual, but the convertible appears to be a bit different from the 2 seat coupe. If it is behind the pass. seat, there is way too much dismantling needed to get to it just to bleed the unit. Can't imagine there isn't another access to bleed it. Would appreciate, someone that has done this on a conv., giving me some guidance. Thanks
Not sure if you got the info you need. It's been a while.
The ABS actuator is on the passenger side, behind the seat, in that cavity area where the top fold down to. In this area, there's a cover like a speaker cover. It should easily pop out. Once it pop out, there should be some precut padding that covers up the ABS actuator.
retrodriver88
09-07-2007 09:58 PM
nismo613
24
08-23-2005 09:15 PM
