i want 300hp
Old 01-11-2005, 05:04 PM
racer69's Avatar
Unhappy i want 300hp
i have a 86 na and i want to go turbo and keep my block how much boost can i do stock and if i add a new intake manifold from a 93 pathfinder and throtle body fom a 92 240sx im so confused need help :headspin:
racer69 is offline
Old 01-12-2005, 03:24 PM
Redbeauty84ZX's Avatar
eh I wouldnt run more then 5 pounds on stock compression. That would put you about 215-220HP. After that your going to need to lower your compression, other wise 300HP isnt going to be reliable with stock compression under boost.
Redbeauty84ZX is offline
Old 01-12-2005, 04:22 PM
ZenArcher's Avatar
Poor Ken, Jason, etc. Too bad they'll never get to 300 reliably with stock compression under boost
ZenArcher is offline
Old 01-12-2005, 05:54 PM
JAMESZ's Avatar
With a good I/C you can run alot more boost then 5psi. Ken is on a stock NA short block making 450rwhp at just over 20psi. The compression really isn't that high on the NA block.
JAMESZ is offline
Old 01-12-2005, 06:18 PM
Im not saying you cant do it, im just saying if it were me I wouldnt run much more then 5 pounds with out lowering my compression or running a IC.
Old 01-13-2005, 01:18 AM
racer69's Avatar
Question
I was going to put a intake manifold from a pathfinder on it for beter air flow I dont know if it increses the compresion does any on know? I was also wanting to run 6 - 12 pounds boost with a vary good ic. I can get a good turbo kit for a grand :roflmao:
racer69 is offline
Old 01-13-2005, 06:20 PM
No it will not increase compression, and with a good intercooler you can run more boost, what turbo are you wanting to run?
Old 01-13-2005, 10:11 PM
racer69's Avatar
Question
my friend looked it up and its a t3 turbo witha sparco ic used kit for 1 grand
racer69 is offline
Old 01-14-2005, 08:42 AM
How many miles are on the turbo????
Old 01-14-2005, 11:24 AM
racer69's Avatar
its a rebult turbo thats all i know
racer69 is offline
Old 01-14-2005, 02:39 PM
sounds fair if its a complete kit.
Old 01-14-2005, 03:56 PM
Z32TTgirl's Avatar
Redbeauty84ZX nailed it on the head.
Z32TTgirl is offline
Old 01-14-2005, 05:22 PM
ZenArcher's Avatar
No, he didn't.
About that "turbo kit", you might want to make sure that is a 1984-1987 z31 turbo, especially if you plan to install it yourself. Otherwise you're going to need some good fab skills. Might be better to get a z31 turbo parts car and take what you need from it. Or just sell your car and buy a turbo z31. The Pathy intake is a good idea but that's a project and you'll need some fab skills for that too. It won't increase your compression.
Old 01-14-2005, 11:29 PM
racer69's Avatar
oh i got fab skill and if i cant do it my buds at the body shop will for free so no problem
racer69 is offline
Old 01-14-2005, 11:45 PM
ZenArcher's Avatar
You'd let a bodyman work on your engine? Whatever dude, I'm outta here.
Old 01-15-2005, 12:10 PM
racer69's Avatar
there is a good mecanich tere dude most body shops have one or two i do body fab and he does the mechanic work he also works on most types of cars :rockon:
racer69 is offline
Old 01-19-2005, 11:17 AM
Banned
00Evan's Avatar
wow does this site suck
:chug:
00Evan is offline
Old 01-19-2005, 07:41 PM
91zxtt's Avatar
Nobody's forcing you to be here.
91zxtt is offline
Old 01-19-2005, 08:08 PM
The Cake Is A Lie!
entropy31's Avatar
yeah man, if it sucks so much then go the hell away and leave us the hell alone.
entropy31 is offline
280zx_82bizox
07-11-2005 08:33 PM
Z_Ferrari
07-18-2001 06:59 PM
Quick Reply: i want 300hp
