Coolant bleeder?
Coolant bleeder?
Hi guys,
Where exactly is the coolant bleeder on this engine? The owners manual says left and ride side of the block, i keep looking and i can't find anything. Is it a bolt? A bolt with a smaller bolt on top?
Near the intake manifold cover passenger side there is a bolt all the way up top, is that the bleeder?
Thanks!
Thanks!
what exactly are you looking for? if you want to drain the coolant there is a drain valve on the radiator. if you think you have air in the cooling system remove the top of the coolant heating valve on the firewall. this is the highest point of the system when sitting on level ground. i've never had an air block but my buddy thinks he did. check the coolant at pressure cap. it should be full up. drive some let the engine cool down and then recheck. If the hose to the expansion tank is crimped not allowing full flow back and forth it will give you fits. Keep expansion tank level to the marks.
The engine bleeds air easily without special bleeder screws. Refill the radiator, open the heater control valve and start the engine. When the thermostat opens, top off the radiator and replace the cap. Make sure the overflow bottle is about 1/3 to 1/2 full. Recheck the radiator level only on a cold engine.
