'87 Z31 Rear Brake Pad Replacement
Old 10-06-2015, 09:23 AM
Virtuoso's Avatar
Did this job a couple of weeks ago, luckily had a set of "Deluxe Plus ORGANIC pads" pbr D 341 D - Made In Australia that fit perfectly.
Used a Haynes Manual as a guide, a NISS factory service manual was available.
Need to relax the parking brake cables and disconnect from calipers by whatever means possible.
Basically ignored the "remove bottom pin only" instructions for the calipers, take BOTH pin bolts out and lay the caliper on top of the CVJ / axle control arms, to expose the pad / clip assembly.
Remove clips with needle nose pliers and the pads fall out. Also ignored the instructions to "turn the piston until the caliper fits over the new pads"..using again, needle nose pliers...turn the piston inward until it is seated back within the cylinder to avoid a trial and error operation fitting it over the new pads..worked perfectly, the caliper went snugly over on the first try.
Used the same brake pad hardware even though both manuals insist on replacing the shims which is an extra expense, applied grease to the shims to hold them in place when fitting them onto the rotor, ALSO apply a little silicon based grease to the contact points between the caliper and it's support.
So far ZERO noise or any sort of problem whatsoever, even after a bit of "hard" braking in traffic....
10 years ago this was a $220.00 shop expense plus hardware..now the cost was nothing other than time and spray brake cleaner.
Have pics, will post later and edit / add a bit more text...hope this helps.
Virtuoso is offline
beg3yrs
01-26-2015 09:35 PM
ivan_zshiro
12-07-2012 05:13 PM
zordietrying
11-17-2010 01:39 PM
SurgeNJ
12-24-2005 12:20 PM
Al Dukes
09-15-2003 01:12 PM
Quick Reply: '87 Z31 Rear Brake Pad Replacement
