Front light: should be easy
Old 08-28-2014, 07:44 PM
aumax74's Avatar
Hello,
I am trying to remove my front light but I am stock.
For sure, that should be easy, I am just missing.
The problem is I cannot access directly the lower screws under the holder...
(and they are seazed)
In the Owner Manual, it looks like the light is "popup" higher
Any suggestion?
Thanks
Max
aumax74 is offline
Old 08-28-2014, 07:46 PM
Donn144's Avatar
You are not trying to take the lens out to change the bulb..right?
Why are you taking it out? Moisture? Condensation?
Donn144 is offline
Old 08-29-2014, 06:26 AM
aumax74's Avatar
Hello Donn,
Neither moisture nor condensation.
My high normal beams are not working correctly. (it is a bit more complex, but let's keep it like that for the moment.)
I have new lens, and I want to check if the problem is the lens or something more electric...
Max
aumax74 is offline
Old 08-29-2014, 09:14 AM
Donn144's Avatar
Did you change the bulb? You do not have to take the lens out for that. Just checking to make sure.
They boys always say one should check he headlight switch. Corrosion sometimes builds up on the copper contacts and needs to be cleaned out. There are videos to demonstrate how this is done.
Donn144 is offline
Old 08-29-2014, 09:55 AM
Grumpy & Helpful
rogerz's Avatar
if you would really like answers that would help you and avoid flames give the following info when you post: year of car, n/a or turbo engine, stick or slushbox. Most of us can tell by the year what model you have ie 85T is a turbo z31. Z cars come in many flavors and they are all different. example 84,85,86 Z31's pretty comparable. there were changes in 87,88,89. in addition 300ZX can refer to two completly different cars the Z31 and the Z32. No mindreaders here the more info you can post the more likely you get a cogent useful answer. The cars with L engine (straight six) changed almost yearly from their introduction. A 240Z and and a 280Z have similarities but they can also have wide variance.
in this case very important. up to 86 it was a sealed beam. after bulb. so advice you get will be dependent on the year
rogerz is offline
Old 08-29-2014, 12:59 PM
aumax74's Avatar
Sorry (still new one the forum),
It is a 1986 NA automatic 2+2.
I will check the video.
thanks for your input!
max
aumax74 is offline
Old 08-29-2014, 01:04 PM
Grumpy & Helpful
rogerz's Avatar
you need to take off the trim ring. one screw as I remember then you can get to the screws to remove the headlight. actually I found easier to pull the whole unit. three m6 and two m8 is what I remember. download the fsm from xenon I think the procedure is in there or in the users manual that came with the car.
rogerz is offline
Old 09-03-2014, 08:41 AM
FlyingT's Avatar
XenonZcar.com Z31 Headlamp Problems
FlyingT is offline
Dirt Winston
03-26-2013 08:26 AM
joel280zt
08-02-2012 06:10 AM
ZThirtyOne
02-12-2012 08:22 AM
gostlrs
12-08-2008 09:55 AM
CrazyLotusTT
07-19-2002 11:59 AM
Quick Reply: Front light: should be easy
