behind dash wire questions
Old 11-07-2015, 10:58 PM
naaaad's Avatar
I have a 280zx 2+2 NA USDM. I bought it a few years ago (running) from a guy who wanted to do his own restoration. Problem is, he ripped most of the wires out of the dash. So many in fact that i am not able to just trace them and splice things together.
I had purchased the one wire strand that goes from the the junction box above the fuse panel over the hump to the gauge cluster. Turns out it was the wires for an analog cluster, my can had the digital. I found an analog cluster online from a 79 and was told it would plug and play. It will not. Only one clip on the wire harness will attach to the cluster.
My question is, Should i find an analog cluster for an 83 and just go with that, or would it be easier to find the wire strand from a 79 to plug into the cluster. And if i go with the second option, will the other clips on the strand plug into the rest of the connections along it's route?
The first pic shows the plugs for the cluster, the second are the wire harness plugs.
Thank you in advance.
(apparently the pics are upside down)
Attached Thumbnails behind dash wire questions-20151024_163851.jpg   behind dash wire questions-20151024_163811.jpg
naaaad is offline
Old 11-08-2015, 09:46 AM
Grumpy & Helpful
rogerz's Avatar
if you would really like answers that would help you and avoid flames give the following info when you post: year of car, n/a or turbo engine, stick or slushbox, digital or analog dash. Most of us can tell by the year what model you have ie 85T is a turbo z31. Z cars come in many flavors and they are all different. example 84,85,86 Z31's pretty comparable. there were changes in 87,88,89. in addition 300ZX can refer to two completly different cars the Z31 and the Z32. No mindreaders here the more info you can post the more likely you get a cogent useful answer. The cars with L engine (straight six) changed almost yearly from their introduction. A 240Z and and a 280Z have similarities but they can also have wide variance.
rogerz is offline
Old 11-08-2015, 11:17 PM
naaaad's Avatar
my apologies. I thought i had put my year in there.
83 280zx 2+2 N/A. Manual transmission. Came with a digital dash that lit up, but didn't show any read outs. (no temp, fuel, RPM, or speed read outs.) The car was missing the HVAC panel, and the radio. Previous owner had lost the keys so he just pulled the ignition cylinder and used a screw driver to start it.
naaaad is offline
Old 11-09-2015, 12:58 PM
borini63's Avatar
What you have in the pictures is a analog under dash harness and you need a digital under dash harness for 83 N/A non turbo witch I have and I will be happy to sell it to you.
Also I have analog cluster to fit your harness that you bought.
Just let me know what you want to do and I will be happy to help.
Jamal
borini63 is offline
Old 11-13-2015, 08:36 PM
naaaad's Avatar
Thank you for the quick response. I don't know if buying the wire harness for the 83 would work or not, (as i said above) my cluster never lit up. I'm afraid that if i buy your wire harness for the digital cluster my speedometer still wont light up.
I know it's a long shot and i don't blame you for saying "no" but would you be willing to let me try the harness first? I would pay for shipping (both ways if needed).
Either way, let me know please.
naaaad is offline
Old 11-16-2015, 08:17 PM
Personally I like the analog gauge cluster much better myself. The digital dash tach is not linear and it drives me nuts. Get the analog cluster preferably from a 1979 or a Canadian or other import so you're not stuck with an 85MPH cluster
FricFrac is offline
Old 11-21-2015, 08:24 AM
borini63's Avatar
I have both clusters 120 miles and a Canadian cluster.
Jamal
borini63 is offline
imaad22
06-03-2013 10:08 PM
LemonHead
09-26-2012 08:56 AM
Jjona5
07-22-2012 08:39 PM
bataradena
07-25-2010 07:35 AM
Al Dukes
09-15-2003 01:19 PM
Quick Reply: behind dash wire questions
