280zx Low rpm miss
280zx Low rpm miss
So, I have a 1982 280zx N/A that is completely stock. I bought the car with a half way done clutch job, so unfortuantely, I've never heard how it is supposed to drive. Ever since I've had it, it has had a really bad miss, but it seems to be at low rpms only. The car doesn't have to be on the road, I can simply hit the gas in neutral and make it miss. I have a video of it
I hope it comes through well. The problem goes away if I hit the gas hard enough. (I didn't make a video of this, but I can do that tomorrow if its needed) It has new plugs, wires, and distributor cap. I have also calibrated the AFM with the water test. I also replaced the gaskets for the fuel injectors (completely separate problem that has been solved) I've spent hours, and I mean hours looking for a vacuum leak. I found a couple very small ones, but nothing major. Unless I'm completely missing an area of the engine (which is possible I suppose) then I don't think I have a vacuum leak. I just need some direction. I was thinking maybe the vacuum advance or something? I'm really not sure. I also plan on checking fuel pressure tomorrow. Some direction would be great. If there is anything that I forgot, feel free to ask. Thank you.
Sorry to be so delayed. I finally figured it out and it turns out the TPS was way off. After adjusting the tps, it runs perfectly fine.
You really need to fix the exhaust leak. I am hoping it is because you don't have a muffler, if not replace the exhaust manifold gasket pronto. The leaks will make the engine have very poor power and run not so good.
dennys93na300z
05-15-2014 12:57 PM
dennys93na300z
05-09-2014 11:23 PM
FireDhusky
08-16-2004 06:14 AM
