need help ASAP!! 280zx 1983 N/A
Old 12-16-2014, 03:20 PM
static.wise's Avatar
The transmission's refill and drain plug bolts will not bulge.
I am working on my driveway with very little leverage underneath.
Anyone have any advice on anything else I can use besides a wrench.
thanks.
static.wise is offline
Old 12-16-2014, 06:22 PM
Steve260Z74's Avatar
Use a map gas torch to heat up the area around the plugs.
Steve260Z74 is offline
Old 12-16-2014, 07:06 PM
ok ill try it thanks
Old 12-16-2014, 07:23 PM
beg3yrs's Avatar
I had to use a torch to get mine off. This was after a good soak with PB Blaster didn't work.
You might consider raising the car on jack stands so you'll have more room. Be VERY careful with jack stands. Make sure all four corners of the stand are solidly in contact with the floor and then make sure the car doesn't wobble AT ALL before you go under there. If it does wobble, find the culpable jack stand, adjust and repeat the process.
beg3yrs is offline
Tosh280zx
10-31-2013 08:33 AM
mottabam
01-06-2009 07:53 PM
LT11
09-11-2008 03:07 AM
dr. buddha
01-12-2004 10:29 PM
Quick Reply: need help ASAP!! 280zx 1983 N/A
