L28 power with n42 block?
Old 05-20-2014, 10:32 AM
zdrifter91's Avatar
I have an n42 block with a n47 head on my 77 EFI L28. Is this a good head to get power out of with out a bore kit or doing an engine swap? If so what kind of cam could i get to get some more power out of it. Where can I get some 600cc fuel injectors as well. What do you think of ITB on this as well?
zdrifter91 is offline
Old 05-20-2014, 10:55 AM
600cc injectors??!?! Are you going turbocharged aimed at 600hp? I see absolutely no need for 600cc injectors no matter how crazy L28 build you make...
Are you just randomly throwing around parts ideas?
NismoPick is offline
Old 05-20-2014, 12:30 PM
zdrifter91's Avatar
stock injectors are 550cc arent they? so i figured just go up a tad more just to get a little more power from the delivery
Old 05-20-2014, 01:55 PM
Stock 280Z / 280ZX n/a injectors are 180cc. 280ZX Turbo injectors are 259cc. A few 400hp+ L28ET guys running MegaSquirt are using Mercedes 450cc injectors.
Not sure where you got the 550cc number from... 600cc is a huge injector for even a modified Z32TT.
As for the ITB's, expect to pay $1k+ for a setup.
Old 05-22-2014, 02:04 PM
zdrifter91's Avatar
I was assuming because of some friends cars run stock 550cc injectors but ok thanks
Old 05-22-2014, 03:58 PM
What are the cars?
Old 05-23-2014, 07:14 AM
zdrifter91's Avatar
rx8, s14, the s14 is running 600cc now
Old 05-23-2014, 10:48 PM
To burst your bubble again:
Stock RX8 injectors are 420cc.
Stock S14 (KA24DE) injectors are 270cc.
So if your friends are telling you 550cc is "stock", they are lying to you.
Old 05-30-2014, 09:40 PM
zdrifter91's Avatar
ok what ever can you seriously just get back to my original question! why does it even matter
Old 05-30-2014, 09:41 PM
zdrifter91's Avatar
s14 is running sr20det by the way not ka
Old 06-01-2014, 09:23 AM
Skully's Avatar
You can make very nice power with a bored out l28, nice and reliable.
Cams you can check out:
Motorsport! Performance Camshafts - The Z Store, Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
ITBs are more for people who have money to throw at their engines, and full blown race setups that are trying to maximize their power outputs. Yes they are good, they will make a difference, but not necessary for a regular average joe driver/weekend warrior. There is kits out there, I think about 1-2k.
600cc injectors aren't an overkill, they are like dropping an atomic bomb on an anthill by putting them in an N/A l28. Typical estimate for injectors is 1cc=1 flywheel hp. Nismo is right, not even a crazy turbo buildup would need those injectors.
Skully is offline
audiofreak97
11-19-2010 06:20 AM
CWHammer
03-24-2008 06:56 AM
Stealth
03-17-2007 08:07 AM
AV240Z
04-28-2003 05:04 PM
280steveX
04-09-2003 06:34 AM
Quick Reply: L28 power with n42 block?
