NV350Z / NVG35 Tech Session
Who: NV350Z / NVG35 + whoever else from this board.
What: Tech Session Where: My House (PM me for directions) When: Saturday January 28, 2006 Why: To help me finish up my car. I am sure I am going to need help finishing up my 350Z on this date. I need to have it all done by Jan. 31st and I am not going to have that much time to work on it. I have 8 days of the week when I can wrench for a few hours after work, but realistically that will probably turn into 4 or 5 days where I actually can do so. Then aside from that I only have one weekend (the 28th and 29th). I really want to get it all done the 28th so I can wash/wax/detail it the 29th and take some photos. Here is what needs to be done... Manditory: Remove all sound deadener glue and the remaining sound deadener Roll Bar padding Seibon TS Hood Re-Locate Odyssey battery Defi Boost Gauge Defi Exhaust Temp. Gauge Defi Oil Temp. Gauge Defi Control Unit Defi Heads Up Display Custom make gauge pod Fire Bottle Fire Supression System DataCam Video Datalogger G-Tech Performance Meter (hardwire) Kinetix Rear Camber / Toe Arms Corbeau FX1 Pro Seat Replace old decals with new ones If We Get Time: Custom fabricate console filler pieces Custom fabricate window switch holders Custom fabricate undertrays Lay speaker box carpet on floor of car Corner balance Adjust Camber / Toe Thats all I can think of for now, but I am sure there is more. I think I may be able to knock out the sound deadener stuff on the weekdays and maybe the Kinetix Rear Camber / Toe Arms and Corbeau FX1 Pro seat. The hood I am sure that I want help on because it is so big and the gauges I will probably need help on too. The rest of that stuff shouldn't be too hard. 1. 350ZNV 2. 3. 4. 5. 6. 7. 8. 9. 10. Oh, and the goal is to have all of this done by 5:00pm so I can make it to the LVRSCCA Awards Banquet by 6:00pm :D |
i wish i was there already, i would be more than willing to help out. thats a pretty good list of stuff to do. might take a while. what are you using to pad the roll cage?
Its the thought that counts :) I am using Moroso roll bar padding.
I should be able to help.
Nice! I am going to need all of the help I can get.
I am working midnights but I may be able to show from like 1-4pm. Otherwise, I can help you 30Jan-01Feb.
Smitty |
Thanks Smitty. If you could show up for a few hours that would be awesome. Hopefully everything is done by the 30th, but if I still need help I will let you know.
What's the deadline for?
[QUOTE=350ZNV]Who: NV350Z / NVG35 + whoever else from this board.
What: Tech Session Where: My House (PM me for directions) When: Saturday January 28, 2006 Why: To help me finish up my car. I am sure I am going to need help finishing up my 350Z on this date. I need to have it all done by Jan. 31st and I am not going to have that much time to work on it. I have 8 days of the week when I can wrench for a few hours after work, but realistically that will probably turn into 4 or 5 days where I actually can do so. Then aside from that I only have one weekend (the 28th and 29th). I really want to get it all done the 28th so I can wash/wax/detail it the 29th and take some photos. Here is what needs to be done... Manditory: Remove all sound deadener glue and the remaining sound deadener Roll Bar padding Seibon TS Hood Re-Locate Odyssey battery Defi Boost Gauge Defi Exhaust Temp. Gauge Defi Oil Temp. Gauge Defi Control Unit Defi Heads Up Display Custom make gauge pod Fire Bottle Fire Supression System DataCam Video Datalogger G-Tech Performance Meter (hardwire) Kinetix Rear Camber / Toe Arms Corbeau FX1 Pro Seat Replace old decals with new ones If We Get Time: Custom fabricate console filler pieces Custom fabricate window switch holders Custom fabricate undertrays Lay speaker box carpet on floor of car Corner balance Adjust Camber / Toe Thats all I can think of for now, but I am sure there is more. I think I may be able to knock out the sound deadener stuff on the weekdays and maybe the Kinetix Rear Camber / Toe Arms and Corbeau FX1 Pro seat. The hood I am sure that I want help on because it is so big and the gauges I will probably need help on too. The rest of that stuff shouldn't be too hard. 1. 350ZNV 2. KENNYZ 3. 4. 5. 6. 7. 8. 9. 10. I could make it for several hours. I'll bring the service manual, just in case. |
Don't expect me to work much cuz I'll be drooling on the TTs (titties :D) most of the time.
1. 350ZNV 2. KENNYZ 3. Me 4. 5. 6. 7. 8. 9. 10. |
1. 350ZNV
2. KENNYZ 3. Me 4. Aarif (although its a far off date and have no idea whats going on) 5. 6. 7. 8. 9. 10. |
Thanks guys. I just got word from VRT that they had a little setback and it wont be tuned by this weekend so that cuts down on my time even more. They are going to deliver it to me when its done sometime next week.
Define setback. Setbacks scare me especially when it comes to high hp engines.
1st setback, they balanced the crank with the wrong set of bearings. The use Nismo bearings, but the crank was balanced with the OEM bearings so they had to re-balance it with the Nismos...
2nd setback, my wheels got powdercoated gloss black instead of flat black. |
2nd setback, my wheels got powdercoated gloss black instead of flat black. Do you have a show are event that you need to make? |
Yes and no. As you can see by my signature, I have been telling everybody that my project will be completely done by the 31st of this month. That is looking more and more like it wont be completely done with all of the stuff on the list above. I also have a track day on the 4-5 of Feb. that I am already pre-registered for.
Ok realistically, this is what I would like to get done over this weekend...
1. Seibon TS Hood w/Sparco hood pins 2. Defi Gauges w/Control Unit in custom housing 3. DataCam OBDII Datalogger 4. Corbeau FX1 Pro Seat 5. Fire Bottle Fire Supression System 6. Kinetix Rear Camber/Toe Arms 7. Odyssey PC 680 Batter (re-located to the rear) 8. Adjust sways to full stiff I will be working on this as much as I can during the week and I am doing two hard all day/night sessions Saturday and Sunday. I also have a few days during the next week to finish up if we don't get all of that done. But, by Thursday February 2nd, I need to have these things done and the car on the trailer ready for Buttonwillow. |
Do you have the car back now?
i want a ride in this beast when i get out there ;)
DAMNIT!
I'd love to help, and I know how to do all that, but I just commited my weekends to work:( Yes, thats right, I am going to be working every weekend until my wife gets down here, I may have a few Sundays off. |
Originally Posted by Love2ridepow
DAMNIT!
Sweet! ........ I'll probably be available to help.
DAMNIT!
Yeah, I'm still down to help, only on Saturday though.
