No Turbo Install For A Few Weeks
Old Nov 4, 2005 | 11:47 AM
scoobybri's Avatar
And no working car for a few weeks either. I was getting some clutch chatter after Cris and I installed the new clutch and flywheel. Turns out that the clutch/flywheel is not the problem...the engine IS!!! There was a problem in the 99 Miata engines that affected a very small percentage of the engines. I'm in the small percentage. There is a thrust bearing that keeps the crankshaft from moving front-to-back. In the bad engines, that bearing is machined incorrectly and allows the crank to move back and forth until the bearing wears out. The crank then starts hitting the engine block and ruins the engine.
The endplay (the distance that a crankshaft can move forward and back in the block) should be about .08mm...8 hundreths of a milimeter. Check out the endplay on my crank...http://www.sallerson.org/video/endplay.wmv
I'm surprised it still runs. I have ordered a new used block and I already have a head being machined. I should have all of the parts here by next weekend. I'm pulling the engine and tranny this weekend if anyone wants to learn about pulling engines.
Old Nov 4, 2005 | 11:54 AM
rob209's Avatar
that sucks... no recourse from Mazda possible?
Old Nov 4, 2005 | 12:19 PM
SinCity350Z's Avatar
Las Vegas Moderator
Ouch...that sucks.
Old Nov 4, 2005 | 01:00 PM
scoobybri's Avatar
Mazda was replacing engines a few years ago, but I don't have a leg to stand on considering that the car is 6 years old and has 80k on it.
Old Nov 4, 2005 | 02:08 PM
rob209's Avatar
it's worth a call, i'd say.
Old Nov 4, 2005 | 03:29 PM
ensmuns's Avatar
Vegas 350Z Moderator
Whew! So I take it we did a good job! I hope the new block will work, but like Rob said, I'd try Mazda to see if they'll replace the powertrain (isn't it 100,000 miles?)
Old Nov 5, 2005 | 05:52 AM
scoobybri's Avatar
Yup, you and I DID do the job right! Don't forget I owe you dinner. You gonna make it to a BWW meet soon? I'll pick up your tab.
Old Nov 5, 2005 | 11:19 AM
ensmuns's Avatar
Oh yeah, I nearly forgot about that. We'll see about it this coming Wednesday.
Old Nov 6, 2005 | 01:03 AM
turbo_jimbo's Avatar
are you getting your motor from seth?
Old Nov 6, 2005 | 01:56 AM
scoobybri's Avatar
Nope. I have a head being worked at a machine shop right now. I have a short block coming from a Miata shop by the end of next week. If the block comes by Friday, I'm going to spend next weekend rebuilding it with a motor install the following weekend.
Here's what I spent the day doing...
Attached Thumbnails No Turbo Install For A Few Weeks-engine2.jpg   No Turbo Install For A Few Weeks-bay2.jpg
Old Nov 6, 2005 | 01:38 PM
ensmuns's Avatar
Old Nov 7, 2005 | 01:31 AM
good luck bro... hope it goes well for ya
Old Nov 7, 2005 | 06:05 AM
scoobybri's Avatar
Topless and no engine??? you betcha!
noobsauce
Aug 12, 2009 11:30 AM
hoov100
Aug 31, 2007 07:57 PM
702Fairlady
Aug 9, 2006 12:21 AM
FubarI33t
May 30, 2006 08:07 PM
midnight300zx
Northeast Region
Jul 30, 2005 09:06 AM
