Geo Metro
man, too bad you don't live in cali, I'd give you 100 bucks for your geo. my friends and I are looking for a beater car to tear everything out of, make a roll cage, make some bush guards, and go run **** over and hit stuff, maybe even see if we could flip it and still make it go.
I say you Bling BLing it out, by this i mean go down to the local Auto parts store get some of those Oh so Nifty Plastic spiners push on rims give it some under glow ground effects (not neons but Xmas tree lights with a 12v addapter) and mabey spend a little cash and stick 2 massive sub woofers in the back and loosen your license plate a bit so it rattels around for that extra coolness
My little brother rolled my 79 Prelude thru a brick wall. The car would not drive,but it started right up. The trans axles where ripped out of the tranny. He was going down Mission between Fremont and Hayward right about union city when he flipped it for some unknown reason. The tow truck had to lift the car out of the wall then dropped it so he could get a better position to flip it.
This is why nobody drives my cars anymore.
2 recomended things to do. easy route, loose the 3 cylinder and trans with it and swap it for a tracker engine suposedly bolts in 1.6 l 16 v .. not sure on power but beats the stock 55 hp! or hell drop in a olds w41 quad 4 190 hp .. wont be bad !. what i wanted to do with mine: weld in a few braces and cut the whole back floor out and install a fiero rear subframe. build a mild 3.1 (sbc rods forged pistons iron heads ect) boost the living **** outta it or spray it. keep the stock engine in front to keep the nose down. or loose it for a fun street car that can do wheelies. i did the research and measured it all out. you will hafta modify the shock towers and install a roll cage to keep it together but i can think of nothing better to do with a 1400 pound car then put a rediclious engine in back of it.
