Selling N/A motor / Parts
Old Jun 24, 2005 | 05:49 AM
mm107's Avatar
Hey guys i recently had to do an engine swap.
I have the old N/A Motor.
I Blew a Connector Rod. (i thought i did! when i took apart the heads a ****ing piston bearing broke and welded itself to one header causing the ticking noise! BULLSH!T PIECE TO FIX BUT WTF i did have to rip apart the engine to the bare block.
I have the engine down to the BARE HEADS/BLOCK/OIL Pan
Remember this actually was a Rebuilt engine 30k miles on rebuild. During the stripping proccess i was looking for metal shavings and couldnt find anything serious.[/list]
1. 1 Header ( the other one got the piston bearing welded to it Can still take it if you like. Maybe might get it machined for ya)
2. 1990 N/A Motor Block - No Vsisble Scratches/Shavings
3. Crankcase
4. 6 1990 N/A Pistons
5. OIL PAN - Has Drain Plug Might be oil Pan from TT
6. Water Pump
7. Sensors
8. Plenium
9. Throttle Boddies Both + TPS
10. Fuel Injectors and Fuel Rail ( Injectors Replaced less then 15k Miles ago.)
11. A/C Compressor
12. Engine Mounts
13. EGR Control Valve
14. I.A.A. Unit
OFFER ME ANYTHING REASOANBLE AND YOU GET IT. I DONT HAVE ROOM TO STORE THESE I JUST NEEDED SOME EXTRA $$ Please offer me something reasonable lol i could put em on ebay and rape some ebayers!
Basically i am stripping this engine to the core. SO IF THERE IS ANY MISC PART YOU NEED FROM A 90 N/A MOTOR THEN LETME KNOW. Anything! I got all pieces i personally stripped it down. Eveyrthing was running perfect. ( the engine was running strong even with the ticking lol and now i found it wasnt a ****in rod but it was a spun bearing.
Old Jun 29, 2005 | 07:41 PM
bardabe's Avatar
Bad Speller
u still got the heads if so how much.
Old Jun 30, 2005 | 11:22 AM
mm107's Avatar
http://asianstarlets.x-provider.com/...l/default.html
dont wory its not a **** site lol but it is hosted on my servers =]
These are ALL parts from the Engine!
ALL PARTS ARE OBO.
Bardabe: 1 head i disasembled to check what happend to my engine. I marked everything. The other one i didnt touch. OBO!
RSuave08
FS: 300ZX (84-89)
Feb 5, 2014 03:11 PM
tay-fu300zxtt
FS: 300ZX (90-96)
Jan 15, 2007 06:36 PM
skittle
Jul 12, 2006 08:39 PM
Seraphic
FS: 300ZX (90-96)
Oct 10, 2005 03:13 PM
VegassaeZ
Apr 19, 2005 05:28 PM
