1991 slicktop twin turbo
Old Jun 25, 2010 | 09:54 AM
hasnain608's Avatar
up for sale is my 1991 SLICKTOP TWINTURBO!! YES I SAID A SLICKTOP TWINTURBO...... car is highly modded 500+ hp, -seriously crazy fast, modifications below
PERFORMANCE MODIFICATIONS: Intake-AshSpec Doolz-Twin JWT Pop Chargers-Samco Boost pipes -Twin HKS SSQV (Recirculated)
Cooling-
MegaZ Radiator Air-Guides-Z1/Howe Upgraded Radiator-Z1/Earls Upgraded Oil Cooler-Nismo Upgraded Thermostat-A/C Delete-AMS Waterpump overdrive pulley-Stock tt fan(stock fans always work the best)
Motor-95+ 615cc Fuel Injectors-300 Degree Fuel Rail w/ Specialty-Z SS Braided fuel lines-300 Degree EGR Delete-AshSpec Massive Side Mount Intercoolers 2.5" I/O-Unorthodox Racing Underdrive Pulley-Z1 GT600R BB Turbos-Stainless steel oil feed lines-Engine Gasket Kit (replaced ALL gas-Engine Gasket Kit (replaced ALL gaskets and seals)-New OEM Oil Pump-Heads Acid bathed, and decked with valve seat resurfacing-Valves resurfaced-OEM block acid bathed and honed-All freeze plugs replaced-OEM lower manifold cleaned and sandblasted-Ford Solid Rubber Motor Mounts
Exhaust-
Specialty-Z 5-bolt Supersplit Downpipes-AMZ Performance Testpipes-Specialty-Z Catback Non-Resonated Exhaust
Drivetrain-
RPS Segmented Flywheel-RPS Max 6 Puck-Nismo Transmission Mount-AMZ Performance 1pc Driveshaft-Stainless steel braided clutch line
Suspension-Ground Control Coilovers (350f/400r)-Koni Adjustable Shocks-SPL Subframe Spacers-SPL Front Camber Arms-SPL Rear Camber Arms-Powertrix Adjustable Tension Rods-Stillen Adjustable Sway bars-Energy Suspension Steering Rack Bushings
Brakes-
Brembo Drilled and slotted rotors (front and rear)-HAWK HPS pads-Stainless steel braided brake lines
Wheels and Tires-
TT Rear (245) Wheels-Bridgestone Potenza S-03 Pole Positions(225/50/16..245/45/16) (500)
Engine Control/Diagnostics-AshSpec ECU-Apexi SAFC-2-AEM TruBoost Gauge-Type Boost Controller-AEM UEGO Wideband-AEM Oil Pressure gauge-AEM Water temp gauge-Detonation Sensor Relocation-PTU Relocated under nose panel
Interior-
Alpine Headunit w/ Ipod Adapter-Rockford Fosgate Dual 6x9's-3 DIN Gauge Pod-Red Stitched Shift ****-Red Stitched Shift boot-Red Stitched E-Brake boot
COSMETIC MODIFICATIONS:-99 Jspec Taillights-CPark Fog Light Intercooler Ducts-TT Rear Flushmount Wing-99 Jspec front bumper-Sportmax 962's 18x9.5 in rear and 18x8.5 in the front-Brand new kuhmo ecsta SPT tires
Old Jun 25, 2010 | 10:19 AM
SpeciallySpiked's Avatar
I'm a Registered User!
Free? :-P What's the asking price?
Old Jun 25, 2010 | 11:12 AM
hasnain608's Avatar
opps asking price is 10k firm
Old Jun 25, 2010 | 11:19 AM
Wow that is a pretty clean TT. And is it a slicktop TT from the factory? That is pretty sweet, and I haven't heard of a Z32 that was. I know of one 280zx turbo slicktop from factory. But that's it. All aside, I would say your price is pretty good, for what you put into it. And for what it is. Good luck on the sale.
Old Jun 25, 2010 | 12:05 PM
hasnain608's Avatar
thanks everyone keeps saying my asking price is to low but i just need to sell it quick because i already got a great deal on my next car
Old Jun 25, 2010 | 05:38 PM
its a swap. no slicktop TT's made here, not sure aboot outside the US i forget if they were or if that was only the 2+2's or vice versus.
and is it a dual pop or a doolz? 2 different companies lol.
Old Jun 26, 2010 | 08:50 AM
hasnain608's Avatar
oh sorry i didnt answer your queston yes it was a twin turbo swap not factory and they dont have a slicktop twin turbo factory made anywhere only a 2+2 tt
Old Jun 26, 2010 | 11:13 AM
^ Okay, I was just wondering. It's pretty cool though, to customize one into a TT. Probably a little lighter because of it? Because aren't the T-tops a little heavier than the slicktops? All aside, good luck with the sale.
Old Jun 26, 2010 | 02:01 PM
hasnain608's Avatar
yup your correct the slikctop are alot lighter and handle better then the ttop hence this is why i wanted a slikctop so i can create a beast
Old Jun 26, 2010 | 05:16 PM
KasbeKZ's Avatar
Pr0n Addict
"a lot"? try "a teeny weency bit". i submit that taking the AC out of the t-top model will give you a comparable trim.
anyway, that's disgusting. between buying and fixing my n/a, i've got $10k in it. damn. can't believe it.
Old Jun 27, 2010 | 08:40 AM
hasnain608's Avatar
idk buddy maybe to many it might feel alittle different but before this i had a ttop twin turbo and then when i brought the slicktop it felt so much different
Old Jun 27, 2010 | 08:47 PM
the weight difference isnt that substantial you should feel a difference. if anything i'd attribute that more to suspension wear (like bushings) and the different rear end setup (the NA's having a more solid setup). but that is beyond the point since this is an AD. so good luck! and looks like a great car! want to trade for an s2000 with 51k miles? lol
Old Jun 28, 2010 | 09:29 AM
hasnain608's Avatar
you might be right, maybe it felt different because i was wowed when i drove the slick for the first time so it was just in my head, and thanks but i need to move on to something more of a sedan, but in the future if i save up and get fund i will definitely build a z again
87zxt
FS: 300ZX (90-96)
Jun 7, 2015 03:08 PM
350z_drifter
FS: 300ZX (90-96)
Jun 14, 2011 07:23 AM
rtmorgan
Oct 10, 2008 10:15 AM
Booker909
FS: 300ZX (90-96)
Apr 9, 2005 06:21 PM
karma
Aug 22, 2003 01:31 PM
