1991 300zx 2+2 NA project
Unfortunately, I am selling my 1991 300zx. I never really got the time to do any of the work I wanted.
$1000 obo
The vehicle did run before I parked it in the garage and proceded to remove the transmission, driveshaft, and exhaust. I also removed a couple of other parts such as the radiator. The exhaust is pretty much worthless. This salvage vehicle has a true 95k miles.
Problems with the car: I believe it has a bad starter solenoid causing an electrical problem. Once I disconnect it, the problem goes away. A sensor on the trans is broken. The car seems to have been in an accident. The front corner where the crossmemeber is welded, seems to have been pushed in a little and then pulled back out. The headlight alignment, mounting, and fenders are fine. The bumper cover seems like it can be buttoned back up a bit. Theres a very small dent on the rear quarterpanel at the wheel well. The steering rack leaks at the boot. There are probably other small problems with the car I haven't even noticed. The car also has 1 flat. This car has a salvage title. This may serve as a parts car for somebody.
Glass is fine and windows work fine. Panels are good. Interior is decent. Engine is good. This vehicle will have to be towed.
I will gladly email pictures of the car. My email address is dropyavickies@aol.com
$1000 obo
