selling my 86 and 88 300zx
i bought them a while back neither running at the time. ive put a lot of time and money into both of them and they now run great.
the cars are in Southport Florida just outside of Panama City.
the 88-white car-red interior
ive had it for around a year and a half without a title. it wasnt running when i got it so ive done the following to make it run right
-spectre cone filter to replace stock air box
-the automatic transmission was shot so i put a 5 speed in with a new clutch/master cylinder (reverse lights work cruise and rev limiter dont)
-oil pan gasket/valve cover gaskets/rear main seal
-new cap and rotor and spark plugs
-new fuel filter/pump/lines
-replaced some vacuum lines
-its had multiple oil changes to clean it up
-transmission has had multiple fluid changes
-ive seafoamed the intake
-got new speedo cable
-timing belt changed along with tentioner
-thermostat
-belts
-fan clutch (you could stop it with your hand at idle)
-radiator hoses
-new ignition module
-short exhaust, thrush welded muffler which sounds pretty nice
-can still hit 100mph stock
now with the drawbacks
-clear coat is mostly gone
-dent in rear right quarter and one on the front right as well
-bright on left is out
-the floor pans are rusty in the back
-tires are a little dry rot
-needs new windshield
-no ac, hasnt been converted
-cruise control isnt on the car
the 86-red car-red interior
ive had it for about 4 months with an Alabama title. it also wasnt running when i got it and here are the things ive done to it
-all the vacuum lines
-the fuel lines and filter
-valve covers and upper intake plenum gaskets
-thermostat and houseing
-belts
-radiator hoses
-new computer
-oil changed
-seafoamed the intake
-spark plugs, cap, and rotor
-timing belt and tentioner
-has fiber glass cowl induction hood (not very sturdy though)
-has a cone filter
-aftermarket steering wheel
-aftermarket rims (thought not that nice anymore)
-cut off the fart can
-rust in various normal places
-radio doesnt have a face plate
-the digital dash doesnt work
-horn doesnt work
-previous owner drove with flat tires and the rims cut the tires
ive loved these cars the whole time ive owned them but im wanting a truck instead or maybe a 80's muscle car :P
im asking $1200 for the white car and $2000 for the red car. $3000 for both.
any questions or if you want more pictures you can email me or text me at
(406) 836-0327
youshimitsue@gmail.com
-thermostat
-belts
-radiator hoses
-belts
-radiator hoses
-new computer
-oil changed
-has a cone filter
-horn doesnt work
(406) 836-0327
