Power window switch
Power window switch
Anyone out there having problems with the power window switch? I have a 2004 350z touring edition and the drivers side window switch seems to be malfunctioning. Just started happening about a month ago at 25000 miles. Doesn't happen all the time. Took it to the dealer who said they couldn't duplicate the problem. I've seen posts on other sites from people who have a similar problem with the Nissan Armada and Titan but nothing about the Z. Anyone got any ideas?
describe the malfunction.
Sounds like it's intermitten.
Next time you take it to the dealer, ask them to put some dielectric grease on the connections for the window switch. Sounds like it might not be making proper contact.
It is intermittent. The malfunction is that is just doesn't work. Window won't go down at all. I have not yet had a problem with it going up, although one time I hit the "up" switch, it went about halfway up, stopped, then went back down (!). I hit it again and it went up fine.
Guest
Posts: n/a
I had this problem on my 2003 Z. It turned out to be the motor in the window itself. I got lucky and the window quit again the day i had it scheduled for service. They checked the motor and found it was an open circuit. They replaced the motor and i haven't had any problem since.
Steve
Steve
Sound like you need to do a reset procedure on it, have you checked the owners manual to see if there is a reset procedure on this? If no then it could be the window switch Switch Doctor, Your Power Window Switch Superstore! Electric Window Switches For All Cars.
stiletto660
Mar 13, 2009 02:11 PM
Comorat2x2
Jan 18, 2006 10:45 PM
HOLY CRAP
