350Z Performance / Technical Discussions related to Turbo charging, Supercharging, Engine, ECU, exhaust, and etc. performance enhancements and Techical related.
U.S. Spec to JDM spec...
Old Dec 27, 2003 | 03:26 PM
Riz Z Speed's Avatar
Administrative Brown Guy
just for technacality's sake, this should be in Z32/tech
but to answer your question, I don't know what all the rage about JDM engines is lately. The JDM engines come with the automatic trans. cam profiles. That and they get smaller turbos than the U.S. spec motors. The JDM motors are rated at 280 but are usually measured at a little beyond that.
It's up to you on how you wanna spend your money. Having the lighter/stronger pistons, rods and rings done to your current motor will probably run you the same as swapping engines will. Unless you do the work yourself, of course. Then the difference will be the end cost of the parts. Replacing the bottom end is like essentially putting in a new motor.
Old Dec 27, 2003 | 04:09 PM
Re: What year Z?
Originally posted by AllmyZs
Just curioys what year Z you are replacing the motor in.
He mentioned JWT Sport 500's. The 500 being plural, I'm guessing he has a Z32.
i.o.
FS: 350Z / 370Z (03+)
Jan 8, 2014 09:13 AM
roneski
Jul 26, 2006 04:22 PM
ZChief
Feb 10, 2004 10:32 AM
raven1
Sep 30, 2002 07:24 PM
4rdhater
Aug 28, 2002 07:46 AM
