350Z Forced Induction Supercharged, Turbo Charged & Twin Turbo
rev-up motor with vortech (one of the first)!
Old Oct 12, 2006 | 04:57 PM
35th ultra"Y"'s Avatar
Cool rev-up motor with vortech (one of the first)!
this is my 35th with the vortech installed i was one of the first to install this system. belive me i had some problems.
Attached Thumbnails rev-up motor with vortech (one of the first)!-motor1.jpg
Old Oct 12, 2006 | 08:24 PM
emo236's Avatar
confuzed member
looks good.....how does this system compare with the stillen sc?
Old Nov 26, 2006 | 06:58 PM
sentry65's Avatar
that looks like a way better belt setup than the standard 287 hp engine vortech
Old Dec 24, 2006 | 08:16 PM
WA2GOOD's Avatar
The two systems are about as far away from each other as any two forced induction kits for the VQ35 as can be. The Stillen is a nice instant throttle response feel, which makes great use of its very limited power gain. The power curve seems to peak early and stay pretty stable.
The Vortech has a good bit of lag before spooling up (around 4-5K rpm's) and then it will unleash its power untill redline. There seems to be only about 2-3K rpm of usable power there, and it is all on the top end. The Vortech will make more power than any stillen will, but the Stillen makes better use of it. IMO, and I have both.
Both are a decent FI kit, both have there pro's and cons. It all depends what your goals and driving style's are like.
Old Feb 27, 2007 | 10:46 AM
sentry65's Avatar
the stock vortech out of the box is pretty weak
I'd upgrade the pulley to the 3.12 pulley at a minimum. If you run shorter gearing like the 3.9 or 3.7 final drive, you'll be higher up in the powerband where there's more boost being made, and the gear multiplication will be higher so you'll get a much better kick in the pants feel.
83turbo280zx
Sep 24, 2011 11:45 AM
35th ultra"Y"
350Z Apperance Exterior, Interior
May 24, 2007 11:26 AM
WA2GOOD
Mar 20, 2007 02:23 PM
prvtman
Feb 4, 2006 12:59 PM
81s280zx
14
Oct 7, 2005 10:48 AM
