Z33 Brembo kit?
Old Jul 25, 2007 | 06:39 PM
silvrhand's Avatar
Snazzy Title
Z33 Brembo kit?
Does these fit on the Z32 and under the stock rims? As many wrecked Z33's that seem to keep popping up I was wondering I'll be able to scope a set of calipers/rotors soon.
Old Jul 25, 2007 | 06:45 PM
entropy31's Avatar
The Cake Is A Lie!
just the calipers, or the rotors as well?? i dont think the rotors will fit, and i need to get a look at the calipers. thats a good idea.
and it's good to see you posting silvr!
Old Jul 25, 2007 | 06:47 PM
MikeZ's Avatar
Nope they don't fit in the Z32's 16 inch rims.
... some kits have adapters so you can just fit the rotors(only) into 17's, not counting the addition size of the Brembo calipers. I wish they did
Goofyz's Avatar
nope
the Brembo or "track" rotors will NOT fit under 16 inch rims. Sorry.
OH, just barely snuck that reply in before me MIKE Z....now, you're suspect...
Old Jul 25, 2007 | 06:49 PM
MikeZ's Avatar
Okay well i was just going correct myself
TWILIGHT ZONE! LOL
Old Jul 25, 2007 | 06:57 PM
entropy31's Avatar
The Cake Is A Lie!
i think that yugo bernie makes adapters for the z33 calipers. but you will need 17" wheels at a minimum. hey, i have 17's!! off i go to the Nissan yard!! i think they have 3 or 4 z33s!
Old Jul 25, 2007 | 07:00 PM
MikeZ's Avatar
http://conceptzperformance.com/Cart/...175.111.39.234
kit,
adapter...
Old Jul 25, 2007 | 07:07 PM
entropy31's Avatar
The Cake Is A Lie!
thats for z32 stock calipers. he wants to use z33 brembo calipers. i just read that the z33 brembo fronts will fit, you just need to drill the mounting holes on the z32 out a bit and re-tap them. for the rear, STi brembos bolt right up with the stock rotor.
Old Jul 25, 2007 | 07:09 PM
MikeZ's Avatar
STI huh, I think you're a lil' crazy
Naw, that is pretty coo;, I had no idea.
Old Jul 25, 2007 | 07:12 PM
MikeZ's Avatar
I like this forum, I learn something all the time
Old Jul 25, 2007 | 07:44 PM
entropy31's Avatar
The Cake Is A Lie!
Rock, Rock On!!!!
Old Jul 25, 2007 | 08:58 PM
Goofyz's Avatar
you don't want to do that
changing the calipers to brembos only and not the master cylinder would be a bad idea. It's simple hydraulics say the stock z32 master pushes 10ccs of fluid during a full pedal travel. that 10cc is spread across the top of every piston inside all the calipers (lets forget about the 1:2 front/back proportioning valve) say it takes 6cc of fluid displacement to push the pistons far enough to make contact with the pads and put pressure on the rotors. That gives you another couple cc's to build pressure against the lines/system and such. Good deal everything works well.
Now assume the pistons on the brembos are bigger or there are more of them i.e. 6 piston instead of 4. So now it takes 9cc just to begin to put pressure on the rotors remember thats nearly the full travel of the pedal. Leaves 1cc of fluid for pressure against the lines/system for stopping power, would make your brakes feel mushy and would completely undo the reason for the upgrade to bigger calipers.
So, long story short, if you are going to upgrade the calipers you should upgrade the Master cylinder too.
Old Jul 25, 2007 | 09:03 PM
would the z33 master cyl. bolt onto the z32 brake booster though?
Old Jul 25, 2007 | 09:04 PM
b300z's Avatar
caught the z fever
i guess some good can come from one of the highest wrecked cars right now.
Goofyz's Avatar
I don't know
is the Z33 a 4 channel ABS or just 2 like the Z32? I really don't know the answer to that one.
Old Jul 25, 2007 | 09:09 PM
you need some of these entropy
http://cgi.ebay.com/Brembo-brake-cal...QQcmdZViewItem
Old Jul 25, 2007 | 09:19 PM
entropy31's Avatar
The Cake Is A Lie!
Originally Posted by hoov100
OMFG TOTALLY!!!!!!! and they would go great with my E-Charger and BOV speaker and my tailpipe turbo whistle and $20 wal-mart spinnerz and my APC Aluminum Wing and my kanji floormats and my NAAAAAWWWWWZZZZ stickers and my big GT-R badge!!!!!!!
Old Jul 25, 2007 | 09:53 PM
whats funny is that my neighbors bought their car stereo system from walmart and it actually sounds better then my $4k home stereo system....
Old Jul 25, 2007 | 09:55 PM
entropy31's Avatar
The Cake Is A Lie!
my calipers are already painted anyways. they look pretty good. red, with the letters in silver, and the oval part behind the letters unpainted. looks pretty slick.
Old Jul 25, 2007 | 09:56 PM
i need a BIG set of TT calipers for my z31, then i need the 13" rotors and the 1" master cylinder from wilwood...
then i can watch my brake lines burst!
Old Jul 26, 2007 | 12:01 AM
MikeZ's Avatar
I liked the lower case b instead of the upper case B for Brembo. SO legit
Old Jul 26, 2007 | 05:50 AM
Comorat2x2's Avatar
To be fair I think that statistic has more to do with the dumb ****** driving them then the car itself.
Added: lol...poser Brembo covers, oh my god...I just realized what wrong with the brake upgrade my neighbor just got. HAHAHAHA!!! Busted!
Old Aug 13, 2007 | 08:18 PM
silvrhand's Avatar
Snazzy Title
You've heard it before but work is still so busy, when I get time off I just walk away from everything. I need to find a new job and starting that thread now, 2 years of this is enough and I am looking to see if I can find another similar salary.
Old Aug 16, 2007 | 02:21 PM
Riz Z Speed's Avatar
Administrative Brown Guy
The front brake pads of the Z32 are the same size and shape as those for a stock WRX also, fyi.
Old Aug 17, 2007 | 12:37 PM
MikeZ's Avatar
WooooOOWZER!
