Z33 Brembo kit?
Z33 Brembo kit?
Does these fit on the Z32 and under the stock rims? As many wrecked Z33's that seem to keep popping up I was wondering I'll be able to scope a set of calipers/rotors soon.
Originally Posted by MikeZ
you don't want to do that
changing the calipers to brembos only and not the master cylinder would be a bad idea. It's simple hydraulics say the stock z32 master pushes 10ccs of fluid during a full pedal travel. that 10cc is spread across the top of every piston inside all the calipers (lets forget about the 1:2 front/back proportioning valve) say it takes 6cc of fluid displacement to push the pistons far enough to make contact with the pads and put pressure on the rotors. That gives you another couple cc's to build pressure against the lines/system and such. Good deal everything works well.
Now assume the pistons on the brembos are bigger or there are more of them i.e. 6 piston instead of 4. So now it takes 9cc just to begin to put pressure on the rotors remember thats nearly the full travel of the pedal. Leaves 1cc of fluid for pressure against the lines/system for stopping power, would make your brakes feel mushy and would completely undo the reason for the upgrade to bigger calipers.
So, long story short, if you are going to upgrade the calipers you should upgrade the Master cylinder too.
Originally Posted by hoov100
i need a BIG set of TT calipers for my z31, then i need the 13" rotors and the 1" master cylinder from wilwood...
then i can watch my brake lines burst!
Originally Posted by b300z
i guess some good can come from one of the highest wrecked cars right now.
To be fair I think that statistic has more to do with the dumb ****** driving them then the car itself.
Added: lol...poser Brembo covers, oh my god...I just realized what wrong with the brake upgrade my neighbor just got. HAHAHAHA!!! Busted!
just the calipers, or the rotors as well?? i dont think the rotors will fit, and i need to get a look at the calipers. thats a good idea.
and it's good to see you posting silvr!
thats for z32 stock calipers. he wants to use z33 brembo calipers. i just read that the z33 brembo fronts will fit, you just need to drill the mounting holes on the z32 out a bit and re-tap them. for the rear, STi brembos bolt right up with the stock rotor.
