z acting weird
Guest
Posts: n/a
z acting weird
when i cruz sometimes my car will kinda freeze in gear, like in third today the car seemed to just stop acelerating while in steping on the gas , then i downshifted and the car was ok again, then the engine light comes on, any help will be appreciated.
Guest
Posts: n/a
Re: z acting weird
If the engine light comes on, and you lose power, and it acts sluggish, you might want to check the wiring to the engine and computer chip. The wiring tells the engine how much voltage it gets, and if the wiring is bad, you lose power, and the car will act sluggish.
If the engine light doesn't come on, and you lose your gears, it's your transmission or clutch.
Guest
Posts: n/a
Re: z acting weird
well my cars going into the shop for a diagnostic the mechanic said its not likely to be trany problem, cuz i still have my gears, but most likely some kind of engine problem, i also found out that the noise is caused by a missfire. thanx for the replies it was all helpfull. ill let you know what it is when i find out.thanx to all
Jennings.brent6
May 30, 2014 11:10 PM
club_sandwich
Nov 17, 2010 04:43 PM
Phantom
Jun 19, 2002 08:58 AM
