Wiring order on injector and coil packs?
Old Aug 14, 2006 | 08:25 PM
91zxtt's Avatar
Hmmm....tough one. Unfortunately, the wiring diagram really won't be much help since the wires don't have any distinct markings. For the injectors and coil packs, your best bet will be to just lay the harness over the plenum. Nissan did an excellent job designing these so that it fits just right. For the most part, each connector finds it's own home. I wish I had a better suggestion.
Old Aug 17, 2006 | 04:42 PM
Aphrodite's Avatar
you could always pin out the wires... looking at the diagrams trace the wires back until you get to a place where they are labled as which ones they are suppose to be connected to, then ohm it out and see which one at the end is connected to the wire that is labled as going to which place... (wow I even managed to confuse myself.... hope you can make some sense of that)
Old Aug 17, 2006 | 05:34 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
... most of them aren't difficult to figure out where they go based on their lengths. If you lay the harness where it's supposed to go (down the center of the plenum), you only have to worry about having 2 options for each pack... guess a few times if it comes down to it.
But the 1 and 2 coil and injector wires are the only ones long enough to reach the 1 and 2 cylinders, the 5 and 6 coil and injector wires are super short and won't reach any cylinders other than 5 and 6, and the 3 and 4 wires are medium length and will reach the middle cylinders with no slack.
In fact, if the harness is laid down the right way, I want to say that the connectors might even come out of the harness in the proper direction, so that might help you get started.
LogansZ
Jan 20, 2014 09:44 PM
bataradena
Aug 7, 2012 01:55 PM
SpeciallySpiked
Aug 17, 2006 07:37 PM
ayperric
Mar 30, 2004 09:29 AM
